GlennWest Posted September 11, 2018 Report Share Posted September 11, 2018 No guys, not wanting to remove mine. I'm curious if there is a space large enough in there to insert a PVC pipe to run refridgeant lines, signal wire and maybe drain. Not wanting to run down back of camper if there is another way. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted September 11, 2018 Report Share Posted September 11, 2018 I have looked behind the plugs and phone jack inside the back cap and there is a lot of room there. In fact in ours there was an undersized piece of insulation just thrown in as if that helped. Underneath the floor there is also some room. The upper part of the rear cap looks much tighter but I haven't looked at that. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
GlennWest Posted September 11, 2018 Author Report Share Posted September 11, 2018 Thanks Randy. I didn't even realize there is outlets there. Couch been back there whole time. I think I will insert phone and take pics. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 11, 2018 Report Share Posted September 11, 2018 Most of them aren't tight to the inner structure. Look to see if the rear window appears recessed into the fiberglass. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
GlennWest Posted September 11, 2018 Author Report Share Posted September 11, 2018 Rear window is ressed. Looks like room is there. That what got me thinking of this. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Big5er Posted September 11, 2018 Report Share Posted September 11, 2018 Glenn, also try looking from the outside. I fished the camera wires through mine going from light to light. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
GlennWest Posted September 12, 2018 Author Report Share Posted September 12, 2018 Thanks Phil 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 12, 2018 Report Share Posted September 12, 2018 How about installing a awning arm in front of the side window. Then hide the lines behind it. Just a thought,. Vern Link to comment Share on other sites More sharing options...
GlennWest Posted September 13, 2018 Author Report Share Posted September 13, 2018 ok, i goggled "pawning arm" and got nothing. what is that. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 13, 2018 Report Share Posted September 13, 2018 Awning arm like on the other side of the Rv. Using just the arm assembly you could hide the plumbing lines behind it maybe. I think getting the lines between the rear windows woul be a problem. I have a Teyon like you do. Now how about boxing enough space on the interior wall in between the window and the slide. It would help hide the soft spot you had trouble with. If you did it a thin as you need but long it may work. Then hide with decorative stuff.. Now I installed a counter on the left side as you enter the Rv. There is enough room between the slide and door to install a 12" cabinet. Made it out of cardboard at first. It seemed to be fine. So I bought a cabinet at Lowes and just sat it there with plywood on top. It still worked good so I finally installed oak plywood on the sides, installed an electric outlet in it at the bottom. And even fished a heating duct into the bottom facing the rear of the Rv. Then last year I made a corian counter top with storage spaces at the wall. Just need to think a little. Vern Link to comment Share on other sites More sharing options...
GlennWest Posted September 13, 2018 Author Report Share Posted September 13, 2018 I agree. That is a small area left from the rear glass. Was looking at that Wednesday. Thanks for tips. I will be doing this likely next month. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rpsinc Posted September 13, 2018 Report Share Posted September 13, 2018 Another thought. I built a chase inside, framed with wood and covered with wainscoting. That way can remove the cover to repair, add to, maintain, replace different things. Intent is to run into a combiner box for solar, use it for wiring from basement too, and could use it for refrigerant lines I suppose. Also, plan on using the cover to hold my TM or other displays needed for solar. Marcel Link to comment Share on other sites More sharing options...
