Malfunctioning electric door lock
dsvohio
1 hour ago, dsvohio said:
Where do we look
If the fob isn't the problem , I'd start checking the connections at the touch pad and the toggle switch .
While checking , don't overlook any grounding points for the circuit . Bad grounds account for a huge amount of electrical gremlins .
Goes around , comes around .
There is a solenoid inside the door, when it fails it is usually in the locked position. To be on the safe side, and upon advice of an RV technician, I began leaving a window large enough to crawl through unlocked, in case the Trimark door solenoid failed in the locked position. You may find extensive reading here.
There is a thread concerning this on another RVing forum where the MH owner spent over $1,000 having the door repaired/replaced after a mobile technician tore it apart to gain access.
