Jimalberta Posted August 26, 2018 Report Share Posted August 26, 2018 Howdy. Our fans are starting to act up....hit and miss operation. Im suspecting the rain sensors. Has anyone else experienced this? <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Chalkie Posted August 26, 2018 Report Share Posted August 26, 2018 6 minutes ago, Jimalberta said: Howdy. Our fans are starting to act up....hit and miss operation. Im suspecting the rain sensors. Has anyone else experienced this? Not to ask the obvious has it been raining or has the humidity been very high when the problem has occured? Link to comment Share on other sites More sharing options...
mptjelgin Posted August 26, 2018 Report Share Posted August 26, 2018 What exactly are they doing? The most common issue I have is the fan failing to come on when the lid is raised. There is a simple brass plunger switch that doesn't make good contact and sometimes needs to be "re-seated". Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
Ray,IN Posted August 26, 2018 Report Share Posted August 26, 2018 Ours has never failed, can't answer. Off topic; FWIW Fantastic Fan covers have a lifetime warranty. Call their phone number to request a replacement, shipping extra though. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
2gypsies Posted August 26, 2018 Report Share Posted August 26, 2018 Sometimes our cover struggled at opening. Every so often we had to clean the rubber and apply 303. Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 26, 2018 Report Share Posted August 26, 2018 If the fan will not open and it has a wall switch with contacts. Move the points in the switch to see it it operates. I just sand the points with 1000 grit sand paper. Now if the lid opens but the fan will not come on it most likely the plunger switch on the outside. It is the ground side of the motor. Push it up and down and maybe rotate it. Hope this helps,. Vern Link to comment Share on other sites More sharing options...
Jimalberta Posted August 27, 2018 Author Report Share Posted August 27, 2018 It might just be the wall switch I dunno but when you push the switch to on sometimes it will work and sometimes it just sits there doing nothing. Once in a while it will raise the lid , start the fan and then just shut down. and no it has not been raining. our bathroom fan is one where you have to raise the lid by hand andthen turn on a switch to run the fan. The fan does not run anymore. I will have to remove it and check it all out. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 27, 2018 Report Share Posted August 27, 2018 The contact points in the switch needs sanded with 1000 grit sand paper. That is if there is contact points. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
Ray,IN Posted August 27, 2018 Report Share Posted August 27, 2018 4 hours ago, Jimalberta said: It might just be the wall switch I dunno but when you push the switch to on sometimes it will work and sometimes it just sits there doing nothing. Once in a while it will raise the lid , start the fan and then just shut down. and no it has not been raining. our bathroom fan is one where you have to raise the lid by hand andthen turn on a switch to run the fan. The fan does not run anymore. I will have to remove it and check it all out. One of our fans began acting like your first paragraph, turned out the be the wall thermostat. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Tcwndsr Posted September 29, 2018 Report Share Posted September 29, 2018 Our rain sensor wasn’t working, vent would stay open when it started to rain. I just went up and gave everything a good cleaning, including the sensor, and everything was good again. Tom and Mare The Breeze RV https://thebreezerv.wordpress.com 2002 National Sea Breeze 2004 Harley Electra Glide Classic Link to comment Share on other sites More sharing options...
