noteven Posted August 19, 2018 Report Share Posted August 19, 2018 Anyone have recommendations for non electric coffee grinders for minimalist boondocking? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 19, 2018 Report Share Posted August 19, 2018 You might not want to work this hard : https://www.amazon.com/Molcajete-Piedra-Negra-Mortar-Pestle/dp/B000VRMKLE Goes around , comes around . Link to comment Share on other sites More sharing options...
dzwiss Posted August 19, 2018 Report Share Posted August 19, 2018 I have been using a Hario mini slim grinder and an Aeropress coffee maker for four years now. It’s beeb a wonderful combination. https://smile.amazon.com/Hario-Ceramic-Coffee-Mill-Mini-Slim/dp/B001804CLY/ref=sr_1_4?ie=UTF8&qid=1534646531&sr=8-4&keywords=hario+grinder 2019 Airstream Flying Cloud 27FB 2011 Ford F350 CC SRW "Be thankful we're not getting all the government we're paying for." Will Rogers Link to comment Share on other sites More sharing options...
Yarome Posted August 19, 2018 Report Share Posted August 19, 2018 Agreed. The Hario Skerton & Kyocera are about, hands down, the best on the market and produced a better grind than many electrics costing hundreds. The "same animal"... just branded by two different Japanese companies. One suggestion I would make though would be to check out orphanespress's website. They have a fairly inexpensive lower bearing modification kit that improves the grind quite dramatically. Especially if you're doing pressed coffee. To note though... if you are wanting a fine grind for espresso then the mod kit isn't for you. It's intended more to keep proper alignment for standard and course grounds. It greatly reduces "play" in the axle for even grinds with minimal "powder" to muddy your cuppa. It "does" however reduce the burr adjustment travel so getting it down tight for a fine expresso grind doesn't work so well. They also have information there to help identify authentic grinders. There are a "great" many knock-off's on the market that leave a lot to be desired. Aka, piss poor performance. I use the full size, because I make more than one cup at a time, and it comes with an airtight cap so... if you're lazy sometimes like me... I'll do a couple days worth of grounds at once and the cap will keep your grounds fresh. Looks like the mod kit is available through amazon now. Not sure if it's the same as orphanespressos, but looks to be. I would still check out their website for alignment instructions and info to identify authentic grinders. Link to comment Share on other sites More sharing options...
noteven Posted August 19, 2018 Author Report Share Posted August 19, 2018 Thanks everyone I’ll check these out... well maybe not the Flintstone model 😀 "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 19, 2018 Report Share Posted August 19, 2018 34 minutes ago, noteven said: Thanks everyone I’ll check these out... well maybe not the Flintstone model 😀 Told ya ... But you have to admit that it'd be the easiest to clean . LOL Goes around , comes around . Link to comment Share on other sites More sharing options...
KnoxSwift Posted September 4, 2018 Report Share Posted September 4, 2018 This is the one I use. Ceramic Burr. Great grind and adjustable. Aikfun Coffee Grinder, Hand Crank Coffee Mill, Quiet and Portable Conical Ceramic Manual Burr Grinder(350ml/12oz) https://www.amazon.com/dp/B07FVG4ZTV/ref=cm_sw_r_cp_apa_vpOJBb65RFPGP Link to comment Share on other sites More sharing options...
noteven Posted September 5, 2018 Author Report Share Posted September 5, 2018 We have a decision! Drum roll... I ordered a Hario ceramic- about C$35 on Amazon do c a. Working good "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
KnoxSwift Posted September 6, 2018 Report Share Posted September 6, 2018 4 hours ago, noteven said: We have a decision! Drum roll... I ordered a Hario ceramic- about C$35 on Amazon do c a. Working good Good choice Link to comment Share on other sites More sharing options...
Yarome Posted September 6, 2018 Report Share Posted September 6, 2018 On 9/4/2018 at 6:10 AM, KnoxSwift said: Aikfun Coffee Grinder... Looks to be a Hario/Kyocera... "remake". 😉 4 hours ago, noteven said: I ordered a Hario ceramic- I'm sure you'll be quite happy with it. Dunno how many years mine has on it. It's been more than a few and still going strong. My french press and cowboy coffee might not seem so... but I'm a little choosy about my coffee and it all starts with the best fresh grind. 😉 Enjoy! Link to comment Share on other sites More sharing options...
KnoxSwift Posted September 6, 2018 Report Share Posted September 6, 2018 Yup when I looked at your link it looked very similar. Ceramic is the key. So far my knock off is going strong 3 year. Link to comment Share on other sites More sharing options...
Yarome Posted September 6, 2018 Report Share Posted September 6, 2018 4 minutes ago, KnoxSwift said: Ceramic is the key. So far my knock off is going strong 3 year. Exactly! Ceramic burr's seem to offer the best grind. The rest is just keeping it in alignment for a consistent grind. Not as critical for some brewing methods than others... and if it ain't broke...... , right. Link to comment Share on other sites More sharing options...
KnoxSwift Posted September 6, 2018 Report Share Posted September 6, 2018 5 minutes ago, Yarome said: and if it ain't broke...... , right. LOL. Well, I bookmarked your brand in case mine ever fails. I don't know if I heard about the different companies back when I bought mine off Amazon, just knew I was looking for ceramic. I have a cast iron one to. The grind difference is night and day. Link to comment Share on other sites More sharing options...
