My 13.5 btu A/C starts it’s run drawing 12-13A, as the unit runs, the Amp draw slowly increases to around 16.5A. Not measured with a Fluke, but don’t understand the increase. Pretty close to sea level at Rainbows End.
Share this post
Link to post
Are you able to measure the voltage at the same time? If the voltage is decreasing then the amperage required to run the unit will increase. Just a thought...
Share this post
Link to post
My first thought also. I assume you are measuring with a clamp-on ammeter?
Share this post
Link to post
Amp draw and heat go hand and hand in a/c systems. Check your condenser and make sure it's clean, depending on the unit you may have remove the cover to clean the condenser from the inside. Another thing that will cause increased amp draw is a weak compressor run cap NO START CAP.
Denny
Share this post
Link to post
My advice runs pretty much with the other fine gents above. I've owned or worked on AC's that drew more current as run time and/or and temperature increases. My similar first thoughts are also to clean the coils and maybe check the capacitor. Often at an RV park (or even where you're located) in high demand hot times line voltage drops making matters worse. Too long or undersized cords also contributes to excess line voltage drop. A good volt meter coupled with an ammeter over time provides good information.
John T
Share this post
Link to post
While voltage sag seems most probable, there are several other things that can also cause the current draw to rise after the compressor has begun to operate. Poor heat transfer due to dirty coils, low coolant pressure, and several other things that could increase the workload on that compressor can cause that issue.
Share this post
Link to post
Thanks for the insight. I’m kinda leaning towards the run capacitor now.
Plugged into a good 30a service today instead of the generator so I would have a stable supply. Sitting at 120v steady to start. Started the A/C and voltage dropped to ~116v, A/C drawing 11.9A. After running ~15min, voltage steady at 116, amperage increased to 14.9A.
As said, not measuring with a Fluke. https://smile.amazon.com/gp/product/B013PKYILS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Share this post
Link to post
THANKS for the feedback,
Good plan, if its NOT a drop in voltage,,,,,,,,,,,,and NOT dirty coils,,,,,,,,,and NOT a refrigerant problem,,,,,,,,,,a weak capacitor could be a problem... and they're not all that expensive. While there may be other problems your "leanings" are hopefully correct, let us know what you find.
John T
Share this post
Link to post
Duh, yes it’s the AC model, I have a Victron on my DC side. I find the little cheap AC meter handy for SHE who loves things that plug in.
Share this post
Link to post
Wire connections, undersized wiring, is the unit two stage.  Its somewhat normal for the amperage to increase slightly as an A/C unit comes up to pressure.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
