NavyKid Posted July 4, 2018 Report Share Posted July 4, 2018 Has anyone had glass randomly break in their RV? I came home to a glass section of my shower shattered this evening. There are four glass sections and the other three are fine(for now). The only idea I can come up with is it being heat or humidity related. I turned off the AC earlier in the day and left it off while I was gone. I don’t think indoor temperatures reached 90 degrees F though. Mainly trying to figure out what happened so it doesn’t happen again. Also, anyone know how to go about replacing the broken glass section? Thanks. I will try to resize the file size of photos to post. Link to comment Share on other sites More sharing options...
chirakawa Posted July 4, 2018 Report Share Posted July 4, 2018 Many glass shops can answer your questions and replace your glass. I've used Binswanger Glass in the past. They may have a location near you. https://www.binswangerglass.com/ Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Ray,IN Posted July 15, 2018 Report Share Posted July 15, 2018 I discovered tempered glass is heat sensitive. I was at home watching TV when a loud crash got my attention. The storm door lower glass had shattered; I suspect due to direct sunlight causing one side of the glass to expand at a different rate than the other. That was 4 years ago, I'm still finding glass shards once in a while. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
