vett Report post Posted May 29, 2018 Air pressure and suggestion what pressure I should be running in my sportchassis rha 350 106 for front and rear axle Share this post Link to post Share on other sites
Grassy Report post Posted May 30, 2018 It really depends what the weight of your truck is and the load that you are carrying. I put softer sidewall tires on mine and are running 95 in front and 100 in the rears but I worked that out with the load table of my tires and having everything weighed so I know what weight is on my 5th hitch. Sure runs better than the 120 in all six that the last owner had... Hope this helps.. Share this post Link to post Share on other sites
Rickl Report post Posted May 30, 2018 Knowing your weights and having a load and inflation table go a long way in determining your ideal tire pressure. Setting the tires to the correct pressure will provide you with the best ride, your best tire footprint, and braking/handling. Share this post Link to post Share on other sites
Pug Report post Posted June 1, 2018 110 to 120 psi in the front works very well. On the rear empty i stay at 95 and loaded i am at 105. my wear is very even. Loaded for is grossing 46,000 lbs and around 4,000 on the pin. Share this post Link to post Share on other sites
