shooter51 Posted May 22, 2018 Report Share Posted May 22, 2018 OK, I need to trap into the vast amount of experience here. What I have in hand: I have a 50 foot roll of 1 inch clear vinyl hose, Enough poly cam lock fittings to make 3 different lengths of hose with caps and plugs for the fittings on each. The question: If you were going to make 3 different lengths of hose, to cover the most often encountered required length of hose, What would those lengths be? Remember, I only have 50 feet of tubing available and 3 pair male/female connector sets, plus plugs, caps and macerator adapter fittings. More hose and fitting procurement is QED, I think 50 feet should cover most any dump situation I'm likely to encounter, What say the smart pigs? The tubing is chemical grade and I will sanitize, then plug/cap each length of hose for stowage in a tote, along with all the other required parts and pieces to "unwaste" the 5er. The tote(s) will ride in a bed locker with the fuel transfer pump and hose/nozzle, for use with the AUX diesel tanks. (the various hookups will require a bit more setup time, but nothing is exposed to the elements while stowed. What am I missing? Thanks in advance, for the redgineering help. Paul If it turns $$$$$$$ dollars into smoke and noise, I'm there. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 22, 2018 Report Share Posted May 22, 2018 10ft, 15ft, 25ft will cover most situations. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
