steelpony5555 Posted May 19, 2018 Report Share Posted May 19, 2018 That's a mouthful......But is anyone using those flat antennas that claim to just put in your attics or even behind your TV. They claim to have a pretty good range. They now sell them from Walmart to Camping World but I have not seen one work to know if they do what they claim. If they do then it would be super simple since I could just put it in a cabinet behind the TV. Link to comment Share on other sites More sharing options...
jcussen Posted May 19, 2018 Report Share Posted May 19, 2018 Think in a best case scenario, with an un amplified omnidirectional you might get reception 10-20 miles from the transmitting tower. There is a reason most rv's come with amplified directional antennas. Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 19, 2018 Report Share Posted May 19, 2018 Omni-directional antennas are often described by antenna knowledgeable folks as "equally bad in all directions" for good reason. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
TXiceman Posted May 19, 2018 Report Share Posted May 19, 2018 In thee ham radio community, it is said the an omni-directional antenna performs equally bad in all directions. With any antenna, the more metal you can put higher in the air the better. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
scouserl41 Posted May 20, 2018 Report Share Posted May 20, 2018 We've used one for 4 years because the roof antenna was bad. It's been very good. We paid $19 for it at OSTCO. There is a booster built in powered by a USB port. We finally replaced the roof antenna at great cost and at times the flat antenna picks up stations the roof antenna won't. They say Omnidirectional but occasionally you have to move it to a side window to get a particular station. Sometimes we can't get PBS with the antenna on the dash but can if we stand the antenna up in a side window, most of the time just throwing it on the dash works best! Before we went full time we gave up cable TV and used one of these antennas in the house. We would get different channels in the rig in the drive than we would get in the house using identical antennas!! BnB 2009 Monaco Cayman DP 38' bnbrv.blogspot.com/ Link to comment Share on other sites More sharing options...
