Lance A Lott Posted May 16, 2018 Report Share Posted May 16, 2018 19 minutes ago, atv_idiot said: Hey VT... If it makes you feel any better... I'll be torching off the cab shocks this weekend. Not only are the bolts rusted/fused together, but they are also seized in the bushings for the shocks themselves.. That's what I did last weekend. Even the 3/4" gun would not turn it in the shock. I tried a drift and sledgehammer and it still would not drive out. As it was the top one over the tank I could not easily cut the head off. I put a small welding tip on the torch and headed the thread end red hot and then let it sit. Drifted right out with a hammer. You can dose with water when they are red hot and they will loosen even better. Not positive about quenching for the bolt stuck in the bushing but it works good on the nut. Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 16, 2018 Report Share Posted May 16, 2018 39 minutes ago, atv_idiot said: Hey VT... If it makes you feel any better... I'll be torching off the cab shocks this weekend. Not only are the bolts rusted/fused together, but they are also seized in the bushings for the shocks themselves.. It appears to be part of the passage into Volvohood. When we preemptively replaced the cab shocks, bags and leveling valve on our truck, prior to final mounting of the bed, the first nut and bolt came off like a breeze. The next two were stubborn but the remaining nuts required a 1” impact. Two of the three bolts came out with various amounts of Kroil and sledgeomatic therapy. The last bolt required a small thermonuclear device, aka plasma therapy. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
atv_idiot Posted May 16, 2018 Report Share Posted May 16, 2018 27 minutes ago, VegasFlyer said: It appears to be part of the passage into Volvohood. When we preemptively replaced the cab shocks, bags and leveling valve on our truck, prior to final mounting of the bed, the first nut and bolt came off like a breeze. The next two were stubborn but the remaining nuts required a 1” impact. Two of the three bolts came out with various amounts of Kroil and sledgeomatic therapy. The last bolt required a small thermonuclear device, aka plasma therapy. 46 minutes ago, Lance A Lott said: That's what I did last weekend. Even the 3/4" gun would not turn it in the shock. I tried a drift and sledgehammer and it still would not drive out. As it was the top one over the tank I could not easily cut the head off. I put a small welding tip on the torch and headed the thread end red hot and then let it sit. Drifted right out with a hammer. You can dose with water when they are red hot and they will loosen even better. Not positive about quenching for the bolt stuck in the bushing but it works good on the nut. What doesnt help is the 30 gallon play tank of race fuel that's mounted between the frame rails and below the bed... and within 10" of the bolts. I think I may try my air chisel first and work my way up to Liquid Wrench (torches) With as bad as the shocks look, I highly doubt there is even any oil left in them, so I may have to get a lil "creative" removing them Link to comment Share on other sites More sharing options...
DesertMiner Posted May 16, 2018 Report Share Posted May 16, 2018 Do you guys have 2 or 4 cab shocks.... Link to comment Share on other sites More sharing options...
atv_idiot Posted May 16, 2018 Report Share Posted May 16, 2018 27 minutes ago, DesertMiner said: Do you guys have 2 or 4 cab shocks.... I only have 2. Never seen one with 4 Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 16, 2018 Report Share Posted May 16, 2018 2 hours ago, atv_idiot said: What doesnt help is the 30 gallon play tank of race fuel that's mounted between the frame rails and below the bed... and within 10" of the bolts. I think I may try my air chisel first and work my way up to Liquid Wrench (torches) With as bad as the shocks look, I highly doubt there is even any oil left in them, so I may have to get a lil "creative" removing them The driver side shock on VT’s truck was seized, it was actually holding the left side near the bottom of it’s travel. 2 hours ago, DesertMiner said: Do you guys have 2 or 4 cab shocks.... 4 for us too, on a 2008. I think the 4 shocks were on older trucks, before they added the torsion rod/damper. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 19, 2018 Report Share Posted May 19, 2018 My 1998 has 4 cab shocks. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 20, 2018 Author Report Share Posted May 20, 2018 Thanks to the mobile mechanic who I write about in another post he got all of the bolts off and shocks off in under an hour, showed up early called to make sure I was there and did it all without the use of any kind of impact. See the post I did about the great mechanic in Pahrump if you want more details on this. He was great at what he did. Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 20, 2018 Author Report Share Posted May 20, 2018 On 5/15/2018 at 8:01 PM, DesertMiner said: Do you guys have 2 or 4 cab shocks.... My cab has two bags and two shocks - see the updated story on Pahrump mechanic. Link to comment Share on other sites More sharing options...
DesertMiner Posted May 20, 2018 Report Share Posted May 20, 2018 You guys with the two bag setup are you also changing the “torsion spring”? Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 20, 2018 Author Report Share Posted May 20, 2018 1 hour ago, DesertMiner said: You guys with the two bag setup are you also changing the “torsion spring”? What is that can you send a picture? Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 22, 2018 Report Share Posted May 22, 2018 I did not on mine, it was in decent shape. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 22, 2018 Report Share Posted May 22, 2018 On May 20, 2018 at 6:22 PM, DesertMiner said: You guys with the two bag setup are you also changing the “torsion spring”? Are you referring to what I would call a track bar, I am sure it has a name, between the shocks? If so unless the bushings are bad or its bent no need in replacing it. It just keeps the cab from moving side,to side excessively. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted May 22, 2018 Report Share Posted May 22, 2018 5 hours ago, Lance A Lott said: Are you referring to what I would call a track bar, I am sure it has a name, between the shocks? If so unless the bushings are bad or its bent no need in replacing it. It just keeps the cab from moving side,to side excessively. That IS a track rod not a torsion spring, it keeps the cab in position. I have seen some cabs with sway bars as well, these could be considered torsion rods? Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
DesertMiner Posted May 22, 2018 Report Share Posted May 22, 2018 Torsion spring...... https://www.google.com/amp/s/class8truckparts.com/volvo-truck-20769319-cab-suspension-torsion-spring.html%3famp=1 Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 22, 2018 Author Report Share Posted May 22, 2018 55 minutes ago, DesertMiner said: Torsion spring...... https://www.google.com/amp/s/class8truckparts.com/volvo-truck-20769319-cab-suspension-torsion-spring.html%3famp=1 You know a picture is worth a 1000 words and just being able to see what you are talking about makes all the difference in the world! I appreciate the picture a lot, and yes I have wondered about when to replace that too. Thanks Cory O - Vegas Teacher P.S. I only have to wake up Wednesday and Thursday for 1/2 days of school then Friday is teacher Check out for the summer! Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 22, 2018 Report Share Posted May 22, 2018 Is your truck going to be ready for a shake down run to the WCR in June???????? 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 22, 2018 Author Report Share Posted May 22, 2018 1 hour ago, Chad Heiser said: Is your truck going to be ready for a shake down run to the WCR in June???????? Not even close. Sorry plus I have family and to many plans to make it out. I still don't have my direct link hooked up, and don't see that happening any time soon. Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 22, 2018 Report Share Posted May 22, 2018 16 minutes ago, Vegas Teacher said: Not even close. Sorry plus I have family and to many plans to make it out. I still don't have my direct link hooked up, and don't see that happening any time soon. Oh well. Maybe next year. I will be back in Vegas for NASCAR again next spring. See you then. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 23, 2018 Report Share Posted May 23, 2018 9 hours ago, Vegas Teacher said: Not even close. Sorry plus I have family and to many plans to make it out. I still don't have my direct link hooked up, and don't see that happening any time soon. 9 hours ago, Chad Heiser said: Oh well. Maybe next year. I will be back in Vegas for NASCAR again next spring. See you then. He could have it ready this weekend but is being a wuss, don’t take that answer Chad......lol John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
Vegas Teacher Posted May 23, 2018 Author Report Share Posted May 23, 2018 8 hours ago, VegasFlyer said: He could have it ready this weekend but is being a wuss, don’t take that answer Chad......lol This is meant jokingly........... Flyer is being a smart @$$ again. You know he and Dolly Trolly go out to eat with me and spend 2.5 hours telling me horror stories about all kinds of accidents that happen with these big rigs due to people not knowing what they are doing, driving ways they should not be and telling me how a semi can outrun a 5.0 Liter mustang going up hill pulling a trailer. However now flyer wants me to pull my dash off, hook up a braking system and put the entire public at risk of me driving my semi and crashing it into a soccer mom and her kids on the way to "Wally World" That is what I like to call Walmart. So what is it I am good an capable or dumb as a box of rocks. Look once again this was written to make people laugh, it is not serious and I am also just being a smart @$$ so when you read this take it with a grain of salt. I know Flyer jokes with me on the forum, I get to see in, many of the social circles we run in with dogs, so I know his ribbing is in good nature like when he says my mechanic sprinkled pixie dust on my truck, what a smart @$$ Later, V.T. - Cory O Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 24, 2018 Report Share Posted May 24, 2018 10 hours ago, Vegas Teacher said: This is meant jokingly........... Flyer is being a smart @$$ again. You know he and Dolly Trolly go out to eat with me and spend 2.5 hours telling me horror stories about all kinds of accidents that happen with these big rigs due to people not knowing what they are doing, driving ways they should not be and telling me how a semi can outrun a 5.0 Liter mustang going up hill pulling a trailer. However now flyer wants me to pull my dash off, hook up a braking system and put the entire public at risk of me driving my semi and crashing it into a soccer mom and her kids on the way to "Wally World" That is what I like to call Walmart. So what is it I am good an capable or dumb as a box of rocks. Look once again this was written to make people laugh, it is not serious and I am also just being a smart @$$ so when you read this take it with a grain of salt. I know Flyer jokes with me on the forum, I get to see in, many of the social circles we run in with dogs, so I know his ribbing is in good nature like when he says my mechanic sprinkled pixie dust on my truck, what a smart @$$ Later, V.T. - Cory O Bring it to the rally and I'll wire up the brakes and Jackaloppee. That way you get work accomplished and learn from others on how too do. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 24, 2018 Report Share Posted May 24, 2018 12 hours ago, Vegas Teacher said: This is meant jokingly........... Flyer is being a smart @$$ again. You know he and Dolly Trolly go out to eat with me and spend 2.5 hours telling me horror stories about all kinds of accidents that happen with these big rigs due to people not knowing what they are doing, driving ways they should not be and telling me how a semi can outrun a 5.0 Liter mustang going up hill pulling a trailer. However now flyer wants me to pull my dash off, hook up a braking system and put the entire public at risk of me driving my semi and crashing it into a soccer mom and her kids on the way to "Wally World" That is what I like to call Walmart. So what is it I am good an capable or dumb as a box of rocks. Look once again this was written to make people laugh, it is not serious and I am also just being a smart @$$ so when you read this take it with a grain of salt. I know Flyer jokes with me on the forum, I get to see in, many of the social circles we run in with dogs, so I know his ribbing is in good nature like when he says my mechanic sprinkled pixie dust on my truck, what a smart @$$ Later, V.T. - Cory O Cory Cory Cory, While from what I have seen, you are great at your vocation, you suck when it comes to listening so I will put it in writing for you. Given the fact that you have worked professionally installing car radios, it would seem fair to assume that you would be able to open the dash covers in your truck. Further, with the above thought process in place, it would be fair to assume that you would be able to mount the Direct link control unit to the void area behind the left side of your dash and run one red wire from the area of the electrical fuse panel to the Jackalopee, which has already been installed and wired. Along with a second red wire to the Directlink control unit and a Blue wire from the Directlink control unit to the Jackalopee. At that point, I told you that I would walk you through and show you how to connnect those three remaining wires and test everything......... The only thing remaining for you to do, would be to reinstall the dash panels, mount the clip holder for the DirectLink manual control, and hook up your trailer and go for it.... While having a properly installed brake controller is essential, it is not something that is going to be quite as dramatic as you posted, especially with the low weight of your current trailer. I gave you this task to build your confidence. I would not have asked you to do it if I did not think you could accomplish the work. While it is true that you still have a lot to learn about mechanical skillcraft, none of this falls into the area of rocket science. I know that you wrote your post in jest, but I also see the fear in your eyes, as the saying goes......lol For everyone else, we now return you to your regularly scheduled program...... John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
atv_idiot Posted May 24, 2018 Report Share Posted May 24, 2018 We fear what we dont understand. I found just digging into something gets me past those fears. It's only $ so when ya F something up, it makes you learn to take your time and double check. I also do my best to research and ask LOTS of questions first Link to comment Share on other sites More sharing options...
HERO Maker Posted May 26, 2018 Report Share Posted May 26, 2018 On 5/23/2018 at 7:48 PM, Alie&Jim's Carrilite said: Bring it to the rally and I'll wire up the brakes and Jackaloppee. That way you get work accomplished and learn from others on how too do. Well, that's worth getting fired up to get to the Rally!!! I also agree with John, you've got what it takes, just get to it! Come on Cory. Before you know it, that school bell will be ringing in a couple of months, and then that excuse will be used! (just funnin) Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
