HHRV Resource Guide change request
NeverEasy
I conuld not find a "contact us" link when I clicked the "Submissions" tab so I thought I will have to put it here.
The SD registration info is incorrect.  A converted truck to RV can be done and is done.  Here is the link to the SD form.
https://www.state.sd.us/eforms/secure/eforms/E1827V3-AffidavitForTruckTractorConvertedToAMotorhome.pdf
I went in prepared with all the document requirements.  The only form they wanted to see was the weight slip.
Chet & Deb
'01 Volvo 660 w/ Smart
'19 Forest River Columbus 320RS 5th wheel
2022 Chev 2500HD Long Bed
Retired CWO4, USN and federal service
Electronics Tech/Network Engineer/Welder/Machinist
The Contact US was temporarily remove because some foreigners were using the Contact Us as a email spoof.
But for South Dakota, there clearly is a link to SD 32-3-65 what is the Code Text for the conversion of a truck to an RV.  So "incorrect" is wrong.  Perhaps you are volunteering to take over the Resource Guide.
Adding the link to the form can be done.
Mark & Dale
www.dmbruss.com
Chet     Have you found out if or what the engine problems were/ are?  We leave for Hawaii tues so will talk when we get back. Hope we can talk before you get u/w!   Pat
The Old Sailor
Bad position sensor on throttle pedal.  They don't just sell the position sensor.  It comes mounted on the throttle pedal.
Chet & Deb
Quote from Resource Guide:  "HDT conversions for private use can be registered as either Commercial or Non-commercial in SD, however there are currently No Registrations Offered in SD as an RV or Motorhome for converted HDT's.
Strictly registrations as a Non-commercial truck."  End quote.
I see some things got changed but it still says the above.
Chet & Deb
You will note that the Resource Guide is a compilation of submitted information from threads in the Escapees Forum.  That statement was submitted by 10-9jc and identified as so.
We do not go back and delete submissions, we add as changes happen.
This kind of nit-picking is probably a sign for the retirement of the Resource Guide.
Mark & Dale
www.dmbruss.com
