PaHunter Posted May 5, 2018 Report Share Posted May 5, 2018 I am trying to find the wire that feeds the back up light on my 2012 Volvo, but everything going in to the delphi connector is white with a yellow stripe. On the outbound side, there is gray, 2 red, a white with yellow and a white with brown? Chris . Sandpiper 379 FLOK, Volvo 2012 730. Link to comment Share on other sites More sharing options...
DesertMiner Posted May 5, 2018 Report Share Posted May 5, 2018 Not the same as at the connector... just tie into the reverse light on the rear of the truck and run the wire forward to where you need it. Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 5, 2018 Report Share Posted May 5, 2018 Attatch it to the red wire on the light then run a new yellow wire to the jackaloppe. Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 6, 2018 Report Share Posted May 6, 2018 Be careful about tapping into the truck light feed, the light monitor may throw faults. On the trailer output there are less issues. We are doing the reverse for the new bed build to run additional turn and brake lights by tapping into the trailer feed. Have you tried testing the wires with a multimeter to find the right wire? John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
DesertMiner Posted May 6, 2018 Report Share Posted May 6, 2018 ? Link to comment Share on other sites More sharing options...
Parrformance Posted May 6, 2018 Report Share Posted May 6, 2018 Would there be a reverse wire in the trailer feed? 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 6, 2018 Report Share Posted May 6, 2018 On the Gen I Volvo, the harness down the left side was truck specific and the harness down the right had had the trailer specific circuits. Backup lights is a trailer thing. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
phoenix2013 Posted May 6, 2018 Report Share Posted May 6, 2018 Rewired few trucks recently after removing the bobtail frame brace with lights. All had the Delphi 280 series connector from the front of the truck connecting to a Delphi plug and harness going to the brace lights. These were "re-created" and powered by a new harness going from the truck connector to the custom ET rear plate and additional lights in the mud flaps holders. The Delphis have alpha marking for the pin locations which are as follows: A locations - Reverse light B locations - Running lights C locations - Left turn D locations - Right turn E locations - Ground Delphi 280 series parts and pieces available from Waytek. There are lots of parts and pieces and Waytek has minimums hence my kit. The easiest thing to do is to cut a wire going to A pin or socket do a nice waterproof wire splice into that wire and plug the new wire into the Jacklaopee reverse light tab. Link to comment Share on other sites More sharing options...
phoenix2013 Posted May 8, 2018 Report Share Posted May 8, 2018 Jackalopee wiring kit Link to comment Share on other sites More sharing options...
