PaHunter Posted April 24, 2018 Report Share Posted April 24, 2018 Forum, Guys, had the truck inspected and there where no faults, they moved the truck and the above code came up. It is a transmission fault, air leak or clutch out of adjustment ?? Thoughts ?? Cost to fix ?? Need to panic or is it something that could wait a week or two ?? Thank you for all the help in advance, Chris Chris . Sandpiper 379 FLOK, Volvo 2012 730. Link to comment Share on other sites More sharing options...
DesertMiner Posted April 24, 2018 Report Share Posted April 24, 2018 Any other symptoms? Any warning lights? Low air pressure? Hard getting into or out of gear? Link to comment Share on other sites More sharing options...
PaHunter Posted April 24, 2018 Author Report Share Posted April 24, 2018 At this time that is all I have, as the truck and I are 1000 miles apart. There were no fault codes, inspector moved truck to inspect and then got code after. Everything else on truck looks good. Chris . Sandpiper 379 FLOK, Volvo 2012 730. Link to comment Share on other sites More sharing options...
Moresmoke Posted April 25, 2018 Report Share Posted April 25, 2018 The following is C&P from an online tech manual. FMI 8 • Clutch system • Low system air pressure • Set point for clutch position can not be reached using normal actuator control Limit for using actuator valves exceeded Clutch position is outside tolerance at disengaged position • Yellow lamp is sent • Harsh start • Harsh shifting • Slow shifting • Slow clutch engagement at start • Air leakage from the following component(s): Clutch cylinder Clutch valve assembly Clutch cylinder air hose Clutch cylinder air connection Sounds like it could be as simple as have tried to put it in gear and move with not quite as much air pressure as needed. Or it could be a bit more involved up to the clutch actuator/linkage/clutch itself. Link to comment Share on other sites More sharing options...
Big5er Posted April 25, 2018 Report Share Posted April 25, 2018 I-shift MID 130 codes listed here And it's what moresmoke said.. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
NTPA Announcer Posted April 25, 2018 Report Share Posted April 25, 2018 X 2 Moresmoke...They've got to have their time. Every time I get in a hurry it reminds me. Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
