Norcold N611 only working on LP
EmPeg
Start by making sure that there is 120V power to the refrigerator's outlet. If you don't have a meter, take a lamp or some other appliance outside and open the refrigerator access panel and look for the power plug the refrigerator is connected to. Pull out the cord from the refrigerator and connect your lamp and see if it turns on. If it does you have power there so next go to the main circuit board and look for two fuses there. Make sure the refrigerator is turned off and then make sure that each of the two fuses is good. Looking at them may not be sufficient so it would not hurt to replace both of them. The 3a fuse is for the 12V power and the 5a fuse supplies the electric heating element.
As a 47 consecutive year RV user and past dealer, I came across bad/open 120 VAC heating elements that caused the problem you're experiencing.  That's easy to check using an ohm meter.  It may well also be what Kirk mentioned, no 120 VAC power   TO  the fridge or a blown fuse or some other simple problem. You gotta have 120 VAC power  TO  the fridge (check wiring and 120 VAC distribution panel and circuit breakers etc) ,,,,,,,,,,,Then a good closed fuse for the 120 VAC circuit,,,,,,,,,,,,,,Then a good continuous heating element.
PS You stated "the fridge switched to LP and won't go to electric"
If the automatic switch over sensing circuit DOES NOT SEE the presence of 120 VAC, it will choose LP gas. Since that's the case, I would FIRST suspect there's no 120 VAC available over the other possible problem I spoke of above (heating element is bad)      orrrrrrrrrrrrr      the small fuse is blown. EITHER can cause it to cool on LP Gas but NOT on 120 VAC. A simple volt meter or a test light or an 120 VAC device plugged into the fridge outlet (if so wired) to see if voltage is present is the first thing to look at. If NOT look at the 120 VAC distribution panel (tripped breaker). Even if there's power to the outlet, however, the fuse still needs to be good !!!!!
Let us know what you find      These manuals may help
https://www.manualslib.com/products/Norcold-N611-2649946.html
http://rvrefrigeratorrepair.com/wp-content/uploads/2016/08/Norcold-Service-N61x-N81x
John T
Edited by oldjohnt
Thanks for your help and suggestions!
I knew I had power before as the light came on in the fridge when door opened.  I also tried plugging the fridge directly to my house via ext cord.
I took the circuit board cover off today and found the glass fuse was blown.  After replacing it, the auto switch now stays on w/o switching to the gas mode.
Now I wait and see if it actually cools the box down.  I'm in a waiting pattern!
She's cooling nicely.
It didn't work on AC from the time we bought it used a few months ago.
I don't know why the fuse was blown, but assume it had been for some time, seeing it was a challenge pulling it from it's holder.
I do thank you for your input and all that try and help each other out.
After 40+ years as an electrical service tech, I assure you that a blown fuse does not always mean there is a problem. Fuses are in some ways similar to a lightbulb as the element must pass all of the current for the circuit all of the time and like the light bulb that element creates some unwanted heat which will eventually damage and weaken it. Fuses do sometimes fail just from age or even from vibrations. It is wise to always have a selection of them available when you travel and always try replacing a blown one first before you spend a lot of time trying to figure out why it failed. If it opens again in a short time that is an indication of some problem.
"I assure you that a blown fuse does not always mean there is a problem"
 EXACTLY they are manufactured relatively cheap and may still open/blow if there's NO problem with the device, as well as open/blow if excess current due to a device problem or a short or excess initial inrush current causes such. Hey what can a person expect from such a cheap piece of *&^%$
  Despite that, in motor control circuits and many industrial applications a good old fashion fuse is still quite reliable as compared to a mechanical circuit breaker with its springs, arms and cam action and all that other "stuff" lol
 Yall take care
 John T
Thank you Kirk and Old John for your comments.
I do agree that the fuse filament is just like an incandescent light bulb.  They weaken over time and at some point will fail.  And my RV is 14 yrs old, even though relatively new to me.
After finding (thanks to responses) the fuses under the circuit board cover, I replaced the blown fuse.  The Norcold manual didn't point it out but said to have a repair technician remove the cover. CYA.
As of this writing, I have had the fridge on electric and it has worked fine, heat on the back and cold inside!   Hopefully the 5A fuse just reached it's end of life!
While it is possible, it is very likely that the fuse was not original. I have known them to last as long as 14 years but it would be pretty rare if the refrigerator spent much time on 120V power. Since you were there I'll also point out the other fuse, probably a 3a one and it is for the 12V power that the control systems need. If it should blow you will have no operation of any type and no lights on the display or the interior. All of those are powered by your 12v-dc circuitry no matter what energy source the refrigerator is using. The propane or the 120V-ac power only supply heating for the boiler that makes the entire system work.
2 hours ago, bigjim said:
Sometimes see through fuses can look perfectly good and be bad so always test it or just replace it.
 EXACTLY I've experienced that several times over the years. Even if to the eye they appear complete a continuity check or an ohm meter can still show an open circuit. I used to restore antique cars and tractors and saw a ton of those old glass fuses that were well over 30 years old all ratty lookin STILL WORKING FINE as mere age alone didn't degrade them. As long as they remain sealed against the elements and aren't stressed from over current they can last years and years, and that's more then I can say for some circuit breakers I encountered !!!
Take care yall
John T
 EmPeg FYI while there may be similarities, what you call a fuse filament isn't EXACTLY "just like" an incandescent light bulb. The delicate filament used in an incandescent light bulb operating in a vacuum is designed and manufactured to produce light (and heat by default) when current flows through it, while the thin metallic conductor inside a fuse produces no light but is sized with precision and has the proper mechanical, metallurgical and thermodynamic properties so it melts open upon x amps of current flow over x time. In all my years I've never seen a light bulb last typically as long as a glass encased fuse (years and years) PROVIDED THAT the fuse isn't operated at its rating for too long too often. SURE they can degrade but not so much due to age versus too many amps too long...............HOWEVER I agree with you it may be called "just like" in that too much current too long too often might mechanically/physically stress it to the point it eventually fails, as would a light bulb due in part to the initial inrush current and its temperature changing resistance properties ............
 Regardless of the reason your old one was blown or how old it was, if that new one is working fine and continues to do so for some time, your heating element and other electronics is likely okay YAYYYYYYYYYYYYYYYYYYYYYYYYYYYY
   Good luck and best wishes
    John T
Edited by oldjohnt
Yo Darryl, Oldddddddddddddddd Edison looking light bulbs sure are  neat. When I attended a Lighting Seminar at GE's NELA Park in Cleveland Ohio I saw some real antique bulbs................  While I didn't restore any antique trucks or tractors that were 116 years old,  I saw some maybe half that with working original glass fuses !!!!!!!!!!!!!
Gotta love antique electrical stuff (To at least look at lol)
Fun chatting with yall
John T
12 hours ago, Kirk Wood said:
Wonder what the longest useful life for a fuse might be? I have a feeling that the new style will outlast the old glass ones.
FWIW I agree. The later blade style fuses have the element better encased inside plastic versus those old glass units with the metal ends over the fragile glass tube. I believe plugging and unplugging them was their worst abuse. The ones I saw still working fine even if 50+ years old looked like they had NEVER been removed.
I'm sure you're  still warm down there in Texas. I came back to Indiana too darn early lol still full timing in the RV.
Best wishes
John T
The frequent vibration of travel with an RV can't be good for the glass type either since the element is suspended, unlike the newer style.
Our weather has been very unstable here too with a high above normal one day then sliding back to well below and back up again. Things are green and spring flowers are starting to bloom but most things are quite late this year.
  • 3 years later...
Our norcold n611 does this after a storm. It’s always the single on / off board on front of fridge it selects it’s on source of entergy it’s just a single button board comes complete in the panel it’s mounted in. Norcold will give you part number to your unit over the phone
Edited by TonyS
Helpful
I’ve got the same issue from this old post. N611 turns on for propane only.
replaced the board and same thing.
Board is getting 120v.  There is 120v on either side of the glass fuse. There are zero volts at the element tabs on the board. The element is at 46 ohms. Fuse is good.
The board also has 12v. The DC fuse is good. Checked the (white/violet wire and green wire) going to the eyebrow board and it’s 12v.
Fridge automatically turns on to propane.  Never recognizes 120v.
Can’t imagine I have another bad board?  (Brand new replacement).
Works fine on propane.
Eyebrow board is a single button with a single led light.
any other ideas?
Welcome to the Escapee forums!
While that is possible, it is very unlikely. This link will take you to a .pdf copy of the service manual which you can download. It is clear that you have 12V available as it must have that in order to operate in any mode. On page 21 there is a procedure for resetting the power board, which is probably worth a try.  If you do get another circuit board, I suggest that you go with a board from Dinosaur Electronics, rather than the OEM version.
  Sorry for not getting into this subject sooner.
  For the fridge not running on electric and a new board.  I would suggest plugging the fridge into separate power source. Not through the rv. You may have a connection somewhere that will pass voltage but not amperage. If that does not fix it then there is probably a connection problem from the plug to the board.
  If I was there I would change all fuses. I would also hook the heating element directly through a fuse to a known good 110 volt power. Check the amps and voltage while the element is plugged in.. do not get shocked from a open connection.
  Just a quick thought,
  Vern in a T-shirt
Hey there Vern in your T Shirt, Good point.   For sure if the 120 VAC heating element is good, has the correct resistance and is continuous, and you temporarily (be careful that's hot 120 VAC, called a man killer) hooked it direct to 120 VAC (limited reasonable time only) and wait n see, that's one way (you or I might but maybe NOT the OP) to tell if she will cool or not using AC ???????????
  Of course don't backfeed 120 VAC to the boards control circuit !!!!!!!!!!! unhook that connection ... Dont allow (disable) the board or controls to try and operate the fridge automatically or on LP gas (best turn gas OFF) when you temporarily jump 120 VAC direct to the heater !!!!!!!!!! Not being there and if the OP isnt qualified to try this  MAYBE BETTER CALL A PROFESSIONAL versus trying things we might ourselves on our fridge !!!!!!!!!! I don't want to be the cause of a fire or blow up your fridge or its board or void any warranty or get you hurt !!!!!!!!!!!! IE don't try this at home if you're not qualified !!!!!!!!!!!
  I hope the fridge is plugged to a good solid 120 VAC source ??? OP check that out ?????????????????
 As you already know if it cools that way, its time to see whether or not the board and eyebrow panel (if and however so equipped) via all its fuses (can look okay yet be bad) and relays and controls (all must be good) and AC input ever applies 120 to the heater ?? A Voltmeter or 120 VAC test light on the heater would tell a lot.
 Ive seen the eyebrow panel or connections (on fridges however and  so equipped) go bad and not manual or auto switch the board as it should so the board never sends 120 VAC to the heater ??
 Oh well this is easier if we were there. I agree something as simple as a bad/loose/resistive connection may be the problem as under no load it would still read 120 ......... but not operate the fridge once current flows.......
 Yall take care now n be safe DONT TRY THIS UNLESS YOURE QUALIFIED its ONLY something I might try......... FIRST insure the heating element is intact, continuous, has right resistance AND SEE IF THE BOARD EVER SENDS IT GOOD SOLID 120 VAC WITH NO RESISTIVE OR BAD/LOOSE CONNECTIONS...
 John T
Edited by oldjohnt
