Ray,IN Posted July 9, 2018 Report Share Posted July 9, 2018 A friend fabricated a mount that bolted onto the 5th wheel pin box to carry a genset. He also ran wiring from the main panel to a 30A plug mounted near the pin box. When using shore or generator power, he used a double-pole, double-throw switch box for that source. The genset stayed on that mount all the time, he could run the air conditioner while traveling too. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
raylen Posted August 3, 2018 Report Share Posted August 3, 2018 we have a 6500 portable onan. Carry it in the back of the truck. its not to loud, works and handles every thing no problems. as for hooking up the 5th wheel, we put a mirror, (4in x 6 in) on the front of the 5th wheel so I could see the tip of the tounge. Then I painted a 2 in strip6 in long in the center right above the pin. Then I painted a 2 in stipe on both sides of the hitch V. Now when backing up to hook up I just keep the stripe on the pin between the V on hitch and it goes in easy. hope this helps SKP 980101990 Bounder 27D by FleetwoodRay and Elen living this beautiful life style and exploring this beautiful country Link to comment Share on other sites More sharing options...
lockmup68 Posted August 3, 2018 Report Share Posted August 3, 2018 and when your onan has issues in the middle of a trip and they can't get you in to check it out for two months (apparently we need to open an onan power generation repair shop. Every shop I called in four states told me 6-12 weeks to get in.) you improvise to keep the AC in the sleeper and the refigerators running on truck and trailer (especially in 106 degree heat). 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
mickeyblueyes Posted August 20, 2018 Report Share Posted August 20, 2018 Lockmup68 I love your set up. How is the sway on the highway? You gotta be 70 feet? Anyway just curious you run 2 refrigerators and a A/C with 4000 Watts? Just askin? Link to comment Share on other sites More sharing options...
Consolenut Posted September 28, 2018 Report Share Posted September 28, 2018 I carry a 12.5JC Onan on the back of my topkick. About 8 inches off the bulkhead of the bed. Sure its 750lbs but its well worth it. My Onan is 45 years old and will be running in another 50 years as well. Tri fuel machine gives me any option i want for any area i might be in Link to comment Share on other sites More sharing options...
lockmup68 Posted October 31, 2018 Report Share Posted October 31, 2018 On 8/20/2018 at 4:44 PM, mickeyblueyes said: Lockmup68 I love your set up. How is the sway on the highway? You gotta be 70 feet? Anyway just curious you run 2 refrigerators and a A/C with 4000 Watts? Just askin? what is sway? That is why you go HDT. I ran the residential fridge in the trailer, the small fridge in the truck and the bunk AC in the truck with the Honda's. Getting the Onan 8k fixed finally, but the Honda's got us through the rest of the trip. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Consolenut Posted November 3, 2018 Report Share Posted November 3, 2018 On 8/3/2018 at 2:54 PM, lockmup68 said: and when your onan has issues in the middle of a trip and they can't get you in to check it out for two months (apparently we need to open an onan power generation repair shop. Every shop I called in four states told me 6-12 weeks to get in.) you improvise to keep the AC in the sleeper and the refigerators running on truck and trailer (especially in 106 degree heat). Old onan's like mine. Have no electronics there voltage output is dictated solely by engine speed. Set the engine speed 62hz no load and all is well. As long as the engine starts its will generate. Tri-fuel Onan even better. Propane runs out. Flip the switch excite the fuel pump and on gas she goes. So unless you run it out of oil and it holds 7 quarts. It will run forever. Never rebuilt the carb simply clean it with a can of carb cleaner and compressed air and your back in business. Simple and bulletproof. Bulletproof is running 96 hours straight with 9kw load on it. 99-105 degree heat. Never even blinked. 2 air conditioners, washing clothes, microwave etc Life as normal improvising power no where. Seen a Honda eb1000 throw a rod and a few champions bite the dust. Those that knocked my JC only listened to it purr as they sweat it off. Link to comment Share on other sites More sharing options...
packnrat Posted November 3, 2018 Report Share Posted November 3, 2018 On 6/5/2018 at 4:07 AM, jenandjon said: Something to look into. I went to Case to get some parts yesterday. Turns out Case IH is making generators. They had some on hand at my dealer. They look well made. Really resemble the Honda generators for a fraction of the price. https://partstore.caseih.com/us/bc3500ig-p2692894.html?csid=1bc5902d92fec39b2555e6db46b9cca2&sl=EN¤cy= http://deltapower.ca/listing/case-ih-2000-watt-inverter-generator-53123.html check them out good. as they are made in comunist china. no service center for any work. forget parts. have to buy a whole unit for even a air filter. oil filters? spark plugs?. Link to comment Share on other sites More sharing options...
