jc2 Posted April 19, 2018 Report Share Posted April 19, 2018 My internet provider/equipment: Time Warner/Spectrum-Technicolor modem/router combo, Windows 10 Pro, all software and drivers were/still kept updated, Ethernet cable replaced. Late last summer/early fall about 4-6 weeks pryor to leaving for our winter spot, I started having the following error messages show on the Dell 17 inch laptop screen using both Ethernet and wifi connections. 1. (90% of the time)"Your not connected to a network"(would usually self correct within 3-5 seconds if not would hit the F5-refresh key. 2. (8% of the time)"Can't reach this page"(would usually self correct as above) 3. (2% of the time) "XXX.com website not responding"(would also self correct as above. Called Time Warner/Spectrum and they sent a so called tech out who couldn't find anything wrong. Left for the winter in Oct and used a Verizon Jetpack with the same laptop for internet and did not receive these messages. Arrived home several weeks ago, reconnected to the Technicolor modem/router combo and the same error message started within 3-4 hours. Called Time Warner/Spectrum and they again sent a "tech" out. He reportedly replaced several outside/inside cable connection. Within 1-2 hrs after leaving, error messages started again. I connected to the Jetpack several days ago and have "not" had one error message. Thoughts anyone............ 2010 Newmar Dutch Aire 4304-Spartan Chassis-Cummins ISL 425hp-2013 Chevrolet Equinox AWD Towed-SKP# 120487-FMCA #402879- Link to comment Share on other sites More sharing options...
fortytwo Posted April 20, 2018 Report Share Posted April 20, 2018 Sounds like a router issue. I'd ask TW to swap it for you. Link to comment Share on other sites More sharing options...
TheDuke Posted April 20, 2018 Report Share Posted April 20, 2018 It's your internal wifi. To test it, buy or borrow an external wifi device. Link to comment Share on other sites More sharing options...
RV_ Posted April 22, 2018 Report Share Posted April 22, 2018 Your WiFi adapter card in the computer is booting later than the computer in cases where it is connecting after a few seconds. In most cases you can fix the problem by going to the manufacturer website and downloading the correct driver for your adapter. Here is a discussion with 72 answers that cover this issue once you click the down arrow to expand to all the replies. https://answers.microsoft.com/en-us/insider/forum/insider_wintp-insider_devices/wifi-driver-problem-on-windows-10-technical/c03f7dc1-cd9d-4547-8d1c-2562fdbd6a37 And here how to reset the adapter or find it and what model it is to find the right drivers.: https://www.bing.com/search?q=reset+wifi+adapter+windows+10&FORM=R5FD3 Hope that helps! RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
