RV Hauler- Horse Totoer for sale - 1996 Volvo M11 Cummins! $31,400 $29,950 OBO I would be willing to take your pickup truck in trade it must be a full size truck! your truck in 25k cash.. lets see what you have?
High and Low jake brake! 10 speed rockwell stick shift not an auto!
miles 880,200
This is one of a kind turn key ready to go with a ton of new parts!
Decked out with a full DVR cam system and 200 watts of solar! We have decided to come off the road and build a house. This truck is super safe and has tons of storage for its size,being a smaller M11 it is better on fuel then most.
THIS RUNS LIKE A TOP! PERFECT !
- Oil change only has 600 miles on it fully greased and ready to go!
- New tie rod ends both just replaced
- Newer Turbo 7,000 miles on it
- Newer Clutch 20,000 miles ago
- New Starter 200 miles ago
- CB
- Newer 2 year old batteries that have been well taken care of with the solar toping them off every day!
- Newer tires 2 years old with 4,000 miles on them ALL 6 TIRES REPLACED !
- New steering box 9,000 miles
- New U joints and carrier bearing 800 miles on them
- New windshield and rubber gasket!
- newer flex exhaust pipe
- Newer radiator core
- The interior was redone 10 years ago..
- New shifter boot
- 1,000 watt new power inverter with volt meter gauge mounted where you can see it.
- Usb ports built in the dash!
- NEW coolent change 600 mils ago
- New 4 cam system DC runs the batteries and solar, tells you speed as well
- Full size Sleeper
-Dual Air ride seats
-All new LED lights interior and exterior
Things wrong with the truck
- The passenger window does not work the motor is good, but the track needs to be replaced the part is cheap I just haven't had the time to do the job!
- Needs a driver side window weather strip, again this part dose not cost much!
-Windshield washer hoses need to be replaced, easy low cost fix.
30 amp charge controller so you can charge the 4 batteries on board with a switch on the fly no need to hook the batteries up at a rv park.
I have all the receipts to show all of the additions made to the truck and all the maintenance done! I also have all the photos of the truck as it was being converted to a RV hauler.
Air ride RV 5th wheel hitch $2,500 with NEW air bags.. Also comes with a goose neck adaptor!
Custom RV hauler bed ALL ALUMINUM NOT LIKE MOST STEEL this bed will not rust! Big tool bays that DONT LEAK!
Email if interested: RossDeprey@gmail.com
Please no tire kickers CASH ONLY!
I will  NOT!  finance this truck FOR YOU  CASH ONLY!!!
RV not included
FOR MORE PHOTOS OF THE TRUCK GO TO THIS LINK!   -  http://www.thedepreys.com/truck.htm
Edited by RossDeprey
CHANGE DIS
Share this post
Link to post
Sign in to follow this
