Devilishjim Posted March 4, 2018 Report Share Posted March 4, 2018 OK I need to know DW is having a helluva time getting me up the ladder to clean the fan blades. So I was on top of the ladder pondering lifes problems and yes the fan was off. But does anybody have a clue how that blade is held on. It would be so much easier to pull the fan off and hand it to DW and let her clean it then she could hand it back to me. I cant quite decipher the end of the shaft, one more step up would help my bad eyes but this post is easier It doesnt feel like a hex head so is it possibly screwed on ? TIA Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
Yarome Posted March 5, 2018 Report Share Posted March 5, 2018 Not sure what model you have, but typically, from the inside... the screen pops down for cleaning. The motor and blade assembly can then be dropped by removing the 4 perimeter screws around the circular plastic frame. As the whole motor/blade assembly unit drops there are 2 wire lead disconnects to the motor. Makes it easy to clean top and bottom of the blades, give the motor a good blow out and oil the motor shaft (if so desired). Link to comment Share on other sites More sharing options...
Yarome Posted March 5, 2018 Report Share Posted March 5, 2018 Re-reading.... it's easier to just drop the whole assembly, clean and remount it. To take off just the blades you almost have to drop the whole assembly anyway to gain access to the back/upper side of the blades and use an allen wrench to loosen the screw bolt that secures the blades to the shaft. Once it's out you can just wiggle the blades down off the shaft. Oh yeah. If your unit has a rain sensor then there may be an additional wire that needs to be disconnected as well. Link to comment Share on other sites More sharing options...
bigbillsd Posted March 5, 2018 Report Share Posted March 5, 2018 That's how I clean mine. I try to stay off the roof if possible till I drag out the scaffold for a once a year maintenance. -Bill 2006 Tiffin Allegro Bus 40QDP Freightliner XCR, 400 hp Cummins Toad 2014 Chevy Equinox (DWM) Blog: http://cowlesmountain.com/Travels/ S&B San Diego Link to comment Share on other sites More sharing options...
bobsallyh Posted March 5, 2018 Report Share Posted March 5, 2018 On our Fantastic, I just remove the screen, then use an Allen wrench into the side of the blades towards the shaft. The hole can at times be hard to see so I put a narrow Magic Marker line at the hole. Link to comment Share on other sites More sharing options...
Big5er Posted March 5, 2018 Report Share Posted March 5, 2018 Straight from the manufacturer How To Clean Your Fantastic Fan MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
2gypsies Posted March 5, 2018 Report Share Posted March 5, 2018 It's simple to just remove the screen and clean the blades. We never found a need to take the whole thing apart. Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
Devilishjim Posted March 5, 2018 Author Report Share Posted March 5, 2018 Thanks for all the help, now I know Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
Kirk W Posted March 5, 2018 Report Share Posted March 5, 2018 11 hours ago, Big5er said: Straight from the manufacturer Thanks! I'm going to need that when Pam gets her "honey do" list put together again. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 5, 2018 Report Share Posted March 5, 2018 12 hours ago, 2gypsies said: It's simple to just remove the screen and clean the blades. We never found a need to take the whole thing apart. Agreed . I do the same . Because we have so little time for 'chores' . LOL Goes around , comes around . Link to comment Share on other sites More sharing options...
Devilishjim Posted March 5, 2018 Author Report Share Posted March 5, 2018 I suggested using the pressure washer, but she wouldn"t go for it Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
