bigredhdt Posted February 27, 2018 Report Share Posted February 27, 2018 It is time to replace air bags on my non singled volvo vnl. Do i really need to replace all 4 bags since the trailer load is low or can I replace 2 and disconnect the supply to the other bags? Link to comment Share on other sites More sharing options...
Quickthrotl Posted February 27, 2018 Report Share Posted February 27, 2018 Im not positive but if you disconnect the bags on one axle it would not hold the axle on the road well and cause it to bounce for lack of better words 2004 Volvo VNL 780 2017 Momentum 376TH 2007 Harley Davidson FLHTC 2009 Smart4two Link to comment Share on other sites More sharing options...
Imurphy907 Posted February 27, 2018 Report Share Posted February 27, 2018 Don't unplug the other axle. As stated above the axle will bounce and ruin those tires in a hurry. Not to mention make a rougher ride. Fix all 4 or single the truck. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
chooseopen Posted February 27, 2018 Report Share Posted February 27, 2018 If it is any consolation the job is pretty simple. I recently replaced the bags on my singled truck in a couple hours. While I had the area torn apart I also cleaned up the frame and spray painted to tidy things up. The bags for my truck cost $115 each from class8truckparts.com Air up your truck (assuming your bags still hold air) Place jack stands under frame. Wait for the old bags to deflate. This didnt take too long with my old leaky bags. Once deflated you will be able to collapse the bag and pull it out. Use breaker bar to loosen the nut on the bottom of the bags. Use breaker bar to loosen the nut on the top of the bags. My new bags came with new brackets too. Unscrew the air supply fitting Put it all back together in reverse. NOTE: When I was all done, my bags would not inflate until I jacked the truck up and lowered it off the jack stands. There must be some sort of valve inside them that causes this to happen. Pics from my project: https://photos.app.goo.gl/GyOFbMmSP3yC0ctG2 2007 Volvo VNL670, Singled, Air ride hitch Link to comment Share on other sites More sharing options...
lockmup68 Posted February 27, 2018 Report Share Posted February 27, 2018 good idea to replace shocks at same time. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
chooseopen Posted February 27, 2018 Report Share Posted February 27, 2018 5 minutes ago, lockmup68 said: good idea to replace shocks at same time. Yeah it is. For me though I recently had a nightmare of a time replacing a front shock. Since I was doing the bag replacement at an RV park, I didnt want to get into that situation again! 2007 Volvo VNL670, Singled, Air ride hitch Link to comment Share on other sites More sharing options...
Chad Heiser Posted February 27, 2018 Report Share Posted February 27, 2018 36 minutes ago, chooseopen said: NOTE: When I was all done, my bags would not inflate until I jacked the truck up and lowered it off the jack stands. There must be some sort of valve inside them that causes this to happen. Pics from my project: https://photos.app.goo.gl/GyOFbMmSP3yC0ctG2 There is no valve inside the bags, it was your ride height leveling valve doing it’s job. Since the frame was supported at ride height on jack stands, it would not add air to the air bags. You could also have manipulated the leveling valve to get it to pass air to the bags or what you did made it work as well. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Cotreker Posted February 28, 2018 Report Share Posted February 28, 2018 At what point do we replace the air bags, years, miles or signs of cracking? Recently camped and wanted to level the rear of the HDT so i drove up on ramps. Air leaked out of one bag most not have liked to be in that angle. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
chooseopen Posted February 28, 2018 Report Share Posted February 28, 2018 3 minutes ago, Cotreker said: At what point do we replace the air bags, years, miles or signs of cracking? I researched this a bit before I replaced mine. I found that cracking is normal. At some point I found a technical bulletin from Goodyear that showed this "normal" cracking. It basically looks like dry rot on tires. I decided to change mine at the point that the "dry rot" cracks started to peel open into what I would call "splits". Flaps of rubber were actually starting to pull away from the surrounding rubber. 2007 Volvo VNL670, Singled, Air ride hitch Link to comment Share on other sites More sharing options...
rickeieio Posted February 28, 2018 Report Share Posted February 28, 2018 2 hours ago, Cotreker said: At what point do we replace the air bags, years, miles or signs of cracking? Recently camped and wanted to level the rear of the HDT so i drove up on ramps. Air leaked out of one bag most not have liked to be in that angle. Backing onto blocks may have caused the leveling valve to try to compensate. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
beemergary Posted February 28, 2018 Report Share Posted February 28, 2018 I replaced my last original @ 950,000mi. and 28 yrs. old on my Peterbilt. On mine there's an internal stop so when there's no air truck will come too far down. Bought the cheaper bag and Whoops. On older Freightliners there's an external stop so any generic bag will work-not on mine. It only cost a few dollars more to go 1st. class. Nice thing about old rubber lines with flare fittings just clamp off or put in dime. Link to comment Share on other sites More sharing options...
beemergary Posted February 28, 2018 Report Share Posted February 28, 2018 On 2/27/2018 at 12:56 PM, lockmup68 said: good idea to replace shocks at same time. On my dual axle Pete I swear the axles don't really move. Only a little over an inch to fenders and they haven't rubbed. I 'll save my money on the back ones. Link to comment Share on other sites More sharing options...
bigredhdt Posted February 28, 2018 Author Report Share Posted February 28, 2018 I'm having a hard time understanding why the axle without bags would bounce as there is a leaf spring and shock. This suspension setup is what you find on pickup trucks. My understanding is that the sole purpose if the air bag is to maintain drive shaft alignment. Thoughts? Link to comment Share on other sites More sharing options...
DesertMiner Posted February 28, 2018 Report Share Posted February 28, 2018 It appears you are confusing the operation of an air bag in an “air ride” suspension and the need of said air bag being inflated correctly to maintain proper drive line angles. Apples and oranges! Have you ever driven your truck with the air bags deflated? Link to comment Share on other sites More sharing options...
noteven Posted February 28, 2018 Report Share Posted February 28, 2018 If we were to call them air springs which is what they are maybe less confusions might occur? The level valve maintains ride height as load changes on the chassis. “Half steel spring” air suspensions still rely on the air spring to carry the load. Level valve is usually on the rear drive axle and maintains the same psi in all springs to hold ride height when the truck is sitting on level surface. Some trucks might have dual level valves but they will be side to side on the same axle. They help with lopsided loads. And they will be happily out of synch with each other most of the time ... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
beemergary Posted March 1, 2018 Report Share Posted March 1, 2018 4 hours ago, bigredhdt said: I'm having a hard time understanding why the axle without bags would bounce as there is a leaf spring and shock. This suspension setup is what you find on pickup trucks. My understanding is that the sole purpose if the air bag is to maintain drive shaft alignment. Thoughts? The air bag is the same as the shakles on the back of a leaf spring. The front of the spring pivots off the front spring hanger. More or less air changes the pinion angles. The secret is to have the pinions or yokes parallel to each other or the back a hair down so when torque is applied the back will go up and be parallel. There's a geometry therm or something that relates to this. Link to comment Share on other sites More sharing options...
VegasFlyer Posted March 2, 2018 Report Share Posted March 2, 2018 On 2/28/2018 at 3:16 PM, bigredhdt said: I'm having a hard time understanding why the axle without bags would bounce as there is a leaf spring and shock. This suspension setup is what you find on pickup trucks. My understanding is that the sole purpose if the air bag is to maintain drive shaft alignment. Thoughts? With no air bags, you do not have a leaf spring, the axle will simply move up and down, pivoting on the front of the leaf spring. The air bag (Air Spring) does maintain frame height with varying weight loads, however, it also works, in conjuction, with the leaf spring and shock absorbers to absorb axle movement forces. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
