Dutch_12078 Posted March 9, 2018 Report Share Posted March 9, 2018 2 hours ago, Mark and Dale Bruss said: I wish I could buy a bracket to mount the Watts regulator to a wall. I do not have the facilities to fabricate one. I current use a couple of conduit clamps but I would prefer something more secure. A couple of small 'L' brackets available at most hardware or home improvement stores should work. You might need to redrill or trim them to fit under the regulator screws. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 9, 2018 Report Share Posted March 9, 2018 5 minutes ago, Dutch_12078 said: A couple of small 'L' brackets available at most hardware or home improvement stores should work. You might need to redrill or trim them to fit under the regulator screws. Probably want screws a little longer so all the threads could be used . Goes around , comes around . Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted March 9, 2018 Report Share Posted March 9, 2018 I scoped out L-brackets but the ideal would be two brackets, each on two of the housing screws. But it may not be obvious, but the regulator body would intrude on a L-bracket between two housing screws. This is where the ability to fabricate something would be handy because the L-brackets would actually have to be curved around the regulator body. Just two L-brackets to the two housing screws closest to the wall would not be very secure to me. The best idea I have some up with, but having acted upon because of the complexity, is to have two through-panel hose connections with the regulator suspended in between. I was surprised in my research that none of the Watt regulators were designed to be mounted, only to be suspended between the plumbing in and out. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 9, 2018 Report Share Posted March 9, 2018 2 hours ago, Mark and Dale Bruss said: I scoped out L-brackets but the ideal would be two brackets, each on two of the housing screws. But it may not be obvious, but the regulator body would intrude on a L-bracket between two housing screws. This is where the ability to fabricate something would be handy because the L-brackets would actually have to be curved around the regulator body. Just two L-brackets to the two housing screws closest to the wall would not be very secure to me. The best idea I have some up with, but having acted upon because of the complexity, is to have two through-panel hose connections with the regulator suspended in between. I was surprised in my research that none of the Watt regulators were designed to be mounted, only to be suspended between the plumbing in and out. Maybe you're not thinking heavy duty . That's why I suggested longer screws / bolts . And , even if you curved the bracket around the body , the pivot/bend point is still the same . That makes 'secure level' the same . Goes around , comes around . Link to comment Share on other sites More sharing options...
TheLongWayHome Posted March 11, 2018 Report Share Posted March 11, 2018 On 3/9/2018 at 1:31 PM, Mark and Dale Bruss said: I was surprised in my research that none of the Watt regulators were designed to be mounted, only to be suspended between the plumbing in and out. Mark, Would this work? WATTS PWMBVIH http://www.watts.com/pages/_products_details.asp?pid=7507 Link to comment Share on other sites More sharing options...
