TheLongWayHome Posted February 24, 2018 Report Share Posted February 24, 2018 Looking for any current recommendation on an audio receiver/equipment for the living area. All the stereo/Electronic store offering seem both physically large with a proportionally high power (>200w/ch) output. Not an audiophile, but appreciate a good surround system, without being blown away! Have a 55" UHD TV - Samsung MU8000. Supports various streaming option and audio system integration. Will be wall mounted. Looking for recommendation on:- 5.1 Surround Sound - Soundbar, sub-woofer (compact and not overly bassy), front/rear speaker. Have a Vizio 5.1 but the sub-woofer is has a very heavy bass for a small space. Receiver (AM/FM, audio streaming, Bluetooth, HDMI support in/out (multiple), ... UHD Video Player (UHD, Blu-ray, DVD, CD) Still in the debate on the video entertainment sources (OTA, satellite, streaming, but probably 2 of 3). Will be FT and mobile - N. America. Anything else to consider? Then there is the bedroom (smaller)! Or any radically different approaches - Sonos, HEOS, ... The RV is not ready yet and the general layout will look something like the layout below, but probably not as wide. (Not the same manufacturer also!). Link to comment Share on other sites More sharing options...
Chad Heiser Posted February 24, 2018 Report Share Posted February 24, 2018 For basic sound requirements in an RV and ease of installation, I have been happy with Samsung all in one Blu-ray surround sound systems. I had a couple of them in my last 5er and they worked quite well. If you are looking for more options and “tune ability” then a good Sony receiver with your choice of speakers and audio/video components is a good option. It is what I have at home and in my current 5er. Sony makes some good receivers and at various price points depending on capabilities. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Zulu Posted February 24, 2018 Report Share Posted February 24, 2018 I suggest an AV receiver like the Marantz NR1508. It has 5 HDMI 4K inputs, 50W per channel, built in WiFi and AirPlay, plus it's one of the shortest AV receivers. I have an Marantz in my AV system. I also suggest some "bookshelf" speakers like this Polk system. Finally, adequate ventilation courtesy of Cooler Guys. BTW, it's almost impossible now to find and integrated system that Chad mentioned with any HDMI inputs which is very, very limiting. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Chad Heiser Posted February 24, 2018 Report Share Posted February 24, 2018 I agree the all in one systems have limited or no HDMI inputs, but there are ways around that. If the TV has digital audio (DA) out, then additional components can be connected directly to the TV through HDMI inputs and then run the sound out through a DA cable (basically a fiber optic cable) to the all in one unit (assuming it has a DA input) to allow surround sound for anything being played to the TV. If the TV doesn’t have DA out, you can pull the DA signal from the HDMI signal with the proper adapter. It all comes down to how much money is in the budget and what quality you require to meet your needs. There are lots of ways to accomplish the goal. Separate components properly matched to your needs will usually give you the best quality, but if cost is an issue an all in one will do the job too 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Smitty77_7 Posted February 24, 2018 Report Share Posted February 24, 2018 We've been pleased with the sound quality of the Marantz NRxxxx series that Zulu identified. Some of Bluetooth built in, other's require a separate moduel for input. (We're using Auris BluMe True Hi-Fi adapter.). I was mostly interested in HiFi vs Surround Sound, so other then suggest looking over the Gallo Acoustics line for a compromise between size and sound quality, I won't bother you with my HiFi speaker setup. I'm a fan of Oppo BluRay's. Their UDP-203 is a smaller form, and high quality product. Suggest Roku be added into the mix, or your choice if you don't like Roku, for ease of future steaming. Amazon's Fire series and Apples Apple TV series are also popular. When installing the equipment, suggest a run of CAT5/6 cable to the area to allows one less WiFi hop from a Tech Cabinet data source area. (One cable is enough, as it can be split if needed in the Audio Cabinet.) We all have different priorities, and HiFi and good sounds are important to me. I've been known to mumble 'Got Tubes' at times... Best of luck to you, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
TheLongWayHome Posted February 24, 2018 Author Report Share Posted February 24, 2018 49 minutes ago, Smitty77_7 said: We've been pleased with the sound quality of the Marantz NRxxxx series that Zulu identified. Some of Bluetooth built in, other's require a separate modue for input. (We're using Auris BluMe True Hi-Fi adapter.). I was mostly interested in HiFi vs Surround Sound, so other then suggest looking over the Gallo Acoustics line for a compromise between size and sound quality, I won't bother you with my HiFi speaker setup. I'm a fan of Oppo BluRay's. Their UDP-203 is a smaller form, and high quality product. 10 hours ago, Chad Heiser said: It all comes down to how much money is in the budget and what quality you require to meet your needs. There are lots of ways to accomplish the goal. Separate components properly matched to your needs will usually give you the best quality, but if cost is an issue an all in one will do the job too 11 hours ago, Zulu said: I suggest an AV receiver like the Marantz NR1508. It has 5 HDMI 4K inputs, 50W per channel, built in WiFi and AirPlay, plus it's one of the shortest AV receivers. I have an Marantz in my AV system. Guys, Thanks for the great suggestions. Clearly it's been a while since I got a new A/V system or receiver!! Plus no recent experience with satellite. It will probably be wise to architect it for all the current media sources. I had planned to put CAT6 cabling (at least one) to the media center. Ever evolving technology. Link to comment Share on other sites More sharing options...
Jack Mayer Posted February 25, 2018 Report Share Posted February 25, 2018 I'll be a little different here.... (well, probably as usual...) I've had surround systems in all my custom rigs. Some very high-end speakers, and some higher end Denon equipment. Unless you are a REAL audiophile I'm now of the opinion that it is a waste of money, adds complexity, and the equipment is subject to failure. The sound from a high-quality soundbar, properly placed, with a wireless subwoofer is WAY more than enough for the RV living area. Now, a true audiophile will want something else, but for those of us that just enjoy GOOD sound, and also sound that can be cranked up without distortion, the soundbars are more than good enough. They really are quite impressive now. Buy the BluRay player of choice to integrate, and you will be good to go. You really do not need more unless you have special needs. I second the Roku, for convenience mainly. I usually cast to my TV (using built-in Miracast technology), but I use PCs. Apple I'm sure is different - since everything seems to be different on Apple. And ALL of my rigs have wired networks in them with hookups in many places....including the entertainment center (and the basement for electrical device monitoring, and the front to support an interface to the truck - even in motion - yes I have a wired connection to the truck). But that is a different topic. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
GlennWest Posted February 25, 2018 Report Share Posted February 25, 2018 We in parks mostly. Can't really crack up a system. Neighbor might not like it 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
TheLongWayHome Posted February 25, 2018 Author Report Share Posted February 25, 2018 But still want OTA AM/FM stations, so therefore the receiver. Not interested in a massive amount off watts. But I'm told that I'm deaf sometimes!! But there is a difference between hearing and heeding 😁 Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted February 25, 2018 Report Share Posted February 25, 2018 I'm with Chad and Jack on this. Pick a soundbar and bass speaker and enjoy. Knowing that the interior acoustics of these moving boxes are not that great to begin with, I wouldn't go overboard. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
TheLongWayHome Posted February 25, 2018 Author Report Share Posted February 25, 2018 Got to read the OP post! Soundbars don't have AM/FM receivers (that I'm aware of). On 2/23/2018 at 9:54 PM, TheLongWayHome said: Looking for recommendation on:- Receiver (AM/FM, audio streaming, Bluetooth, HDMI support in/out (multiple), ... Link to comment Share on other sites More sharing options...
Zulu Posted February 25, 2018 Report Share Posted February 25, 2018 2 hours ago, Alie&Jim's Carrilite said: I'm with Chad and Jack on this. Pick a soundbar and bass speaker and enjoy. Knowing that the interior acoustics of these moving boxes are not that great to begin with, I wouldn't go overboard. So . . . I'm watching the movie Pearl Harbor in my Class A "box" with a 5.1 speaker system. There's a part in the movie when Japanese planes first appear over Pearl Harbor. As they come into frame you can only hear them on the rear speakers -- so the planes sound as if they're coming from behind you and moving right over you. Nothing like it. Similar experience with other movies. Sure, an RV probably won't get THX certified, but a standard 5.1 speaker system is the sh&* if you can go that route. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
lockmup68 Posted February 27, 2018 Report Share Posted February 27, 2018 sonos playbar and sonos sub, some sonos play:1's for rears if wanted. But playbar and sub are plenty. bluetooth to the playbar, can get am/fm app on your phone, or get a sonos connect and hook in traditional receiver. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 3, 2018 Report Share Posted March 3, 2018 You can get almost every am and fm station in the country with software. I routinely listen to "local" Co Springs stations with my phone connected with bluetooth to my speakers. It uses very little data. So that is a "reasonable" option if you have data. Traveling the county I have had only 3 hours the last three years I've been without an Internet connection. BUT there are still plenty of places where no cellular data is available...but I'd bet radio is not, either, in many of them. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
TheLongWayHome Posted March 4, 2018 Author Report Share Posted March 4, 2018 I❤Radio? Free but with ads. Amazon Music is you have Amazon Prime? Pandora or one of the pay subscriptions? What is the down rate per hour for cellular ( approx)? Link to comment Share on other sites More sharing options...
NoDirectionHome Posted March 4, 2018 Report Share Posted March 4, 2018 I'm an audiophile, so consider that in my response. DO NOT get a sound bar! Go to an audio shop. Not a big box store and tell them what you want to do and audition some bookshelf speakers. Those along with a matching center speaker (it does about 90% of the work in dialog) will have you thrilled with listening at lower volume levels. You will hear things in familiar music you've never heard before. You don't need a lot of power if the speakers are efficient (>90 Spl). Rear surrounds add very little to even movies. you can skip these or add them later. I promise you even the most tin ear can tell the difference and make a sound bar sound like a transistor radio. Another option are studio monitors. They are usually powered so you'd only need a tuner/pre-amp. You can listen to them at stores like Guitar Center. The subwoofer is for low frequency. You'll find some that just thump for movies, and quite musical ones for music like a stand up jazz bass. Go listen! "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
jcussen Posted March 4, 2018 Report Share Posted March 4, 2018 1 hour ago, TheLongWayHome said: I❤Radio? Free but with ads. Amazon Music is you have Amazon Prime? Pandora or one of the pay subscriptions? What is the down rate per hour for cellular ( approx)? https://www.consumerreports.org/cars-how-to-keep-streaming-audio-from-chewing-through-your-data-plan/ I like tune in radio, bluetooth it from my phone to my soundbar, or my coach radio. Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
bigbillsd Posted March 5, 2018 Report Share Posted March 5, 2018 My Cuz picked up one of these Pyle - Premium Rack Mount Bluetooth Receiver, Home Theater Amp, Speaker Amplifier, Bluetooth Wireless Streaming, MP3/USB/SD/AUX/FM Radio, 200 Watt, w/ Digital ID3 LCD Display from - PDA7BU and says its really nice. I haven't seen it though. I prefer to use my in Dash Stereo, it already has everything I need once I upgraded the speakers. -Bill 2006 Tiffin Allegro Bus 40QDP Freightliner XCR, 400 hp Cummins Toad 2014 Chevy Equinox (DWM) Blog: http://cowlesmountain.com/Travels/ S&B San Diego Link to comment Share on other sites More sharing options...
wcurtin1962 Posted December 2, 2018 Report Share Posted December 2, 2018 High end Bluetooth headphones could be an option to listen to music at high levels without anybody complaining. Link to comment Share on other sites More sharing options...
GlennWest Posted December 2, 2018 Report Share Posted December 2, 2018 Got our older Teton. Upgraded the entire sound system. Guess what, we don't use it. Just too much for the small space in here. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
oldjohnt Posted December 2, 2018 Report Share Posted December 2, 2018 I was somewhat of an audiophile wayyyyyyyyyyy back in college (EE school at Purdue) with huge heavy high power KT88 power tube amps, Wharfedale super heavy sand packed wall speaker cabinets, tuned bass reflex, Fisher, McIntosh, Marantz and my hand wired Dynaco Stereo 70 etc etc but my big surprise is how the modern compact lightweight even plastic enclosed Bose wave speakers SOUND AS GOOD AS ALL MY HUGE HEAVY ANTIQUE EQUIPMENT LOL Due to such small and acoustic unfriendly space in an RV I don't see any super expensive high quality system as providing as much "bang for the buck" as compared to the benefits derived if located in a large well designed residential home entertainment center. My study of acoustics indicated the physics, size, shape, walls and floors etc WAS AS IMPORTANT OR MORE THEN THE EQUIPMENT ??? IE for my money and my own personal choice Id opt for a good Bose based system but as always to each their own preference budget and choices. What type of an audio system is about like asking what brand of oil one should use lol Take care yall John T Link to comment Share on other sites More sharing options...
wcurtin1962 Posted December 2, 2018 Report Share Posted December 2, 2018 My bulky equipment sets in storage while I use a $500 sound card and high end Sony headphones to listen to music. I use a ipod with the factory radios in the work cars I drive. Most of them have very good sound. I intend on getting a pre 85 class A. I will surface mount on sink high end bookshelf speakers rather then mess with installing car speakers. I have a tubed preamp and a Adcom power amp in storage plus Klipsch kg 4.2 speakers in storage. I'm thinking about building them into the class A. Link to comment Share on other sites More sharing options...
rpsinc Posted December 2, 2018 Report Share Posted December 2, 2018 I investing into a whole house system in my S&B with B&W speakers to volume controls throughout, and a Paradigm theater system for TV. It is powered by an NAD receiver but the thing has lost the center channel and needs some upgrades. Havent had time to remove it from the rack to take it in for service or repair. Or perhaps replacement depending on what is discovered through diagnostics. Marcel Link to comment Share on other sites More sharing options...
wcurtin1962 Posted December 2, 2018 Report Share Posted December 2, 2018 NAD was my first choice till the shop I was planning on steered me to ADCOM. I ended up with a tube preamp because it was the only way I could afford to get below 10,000 Hz. It is a proto type that was setting at Stereo Lab in Columbus Ohio. I asked how low would it go. They said they didn't know so they put it on an oscilloscope and told me it was passing DC. I had this crazy notion of getting a pair of Bag End subwoofers. I had them call the company a start up called Sound Valves in Columbus if they could sell it to me. They said $500.00 and I bought it. Other then the balance control working backwards it has served me well. I scored a Nakamichi cd player 2 off EBay for $150 in 2009. I like to listen for screw ups in recordings like chair squeaks, pages being turned, music stands being knocked over. Link to comment Share on other sites More sharing options...
Jaydrvr Posted December 2, 2018 Report Share Posted December 2, 2018 25 minutes ago, wcurtin1962 said: NAD was my first choice till the shop I was planning on steered me to ADCOM. I ended up with a tube preamp because it was the only way I could afford to get below 10,000 Hz. It is a proto type that was setting at Stereo Lab in Columbus Ohio. I asked how low would it go. They said they didn't know so they put it on an oscilloscope and told me it was passing DC. I had this crazy notion of getting a pair of Bag End subwoofers. I had them call the company a start up called Sound Valves in Columbus if they could sell it to me. They said $500.00 and I bought it. Other then the balance control working backwards it has served me well. I scored a Nakamichi cd player 2 off EBay for $150 in 2009. I like to listen for screw ups in recordings like chair squeaks, pages being turned, music stands being knocked over. Following.. Link to comment Share on other sites More sharing options...
