Wrknrvr Posted February 23, 2018 Report Share Posted February 23, 2018 I have a 2000 Cummins N14 and the fan clutch selinoid is bad. I have tried to search for that part on the net and it just will not appear. Share hope someone on hear may be able to provide a part number. Thanks,. Vern Link to comment Share on other sites More sharing options...
jkoenig24 Posted February 23, 2018 Report Share Posted February 23, 2018 Have you tried spelling it "solenoid"? Link to comment Share on other sites More sharing options...
beemergary Posted February 23, 2018 Report Share Posted February 23, 2018 Is it the air operated fan clutch that uses a 12 volt solenoid to engage it? If so that solenoid should be a generic part that fits lots of truck brands. Horton is a big truck air operated fan name. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted February 24, 2018 Report Share Posted February 24, 2018 Usually the solenoid is used to release the fan clutch. The default off is fan engaged. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Wrknrvr Posted February 24, 2018 Author Report Share Posted February 24, 2018 I took the seliniod off today and found a part number. New part ordered. Thanks for the replies on the subject. Vern Link to comment Share on other sites More sharing options...
DesertMiner Posted February 24, 2018 Report Share Posted February 24, 2018 Can you please share the part#.... might help out the next guy? Thanks Link to comment Share on other sites More sharing options...
Wrknrvr Posted February 24, 2018 Author Report Share Posted February 24, 2018 This is more info that may help someone. Searching for a fan clutch selinoid did not produce very good results. But once I found the name Horton and put that in front of said subject, lots of info came up on the net. My part is a Kysor 1056-08287-03. Now that is my part number. It may not be yours. Now when I unplugged the wiring to the seliniod the fault went inactive on the dash readout. The problem is that when the seliniod is not passing air to the clutch then the clutch runs all the time. So fuel mileage was down and a little more noise in the cab.The seliniod quit on our way south last fall during a not so fun trip so I just now got to it . Now if you would pay attention to temperature control , you could bypass the seliniod and just put air direct to the clutch that is until proper parts are installed. Now since I do RV repair, my mind did think of installing a gas valve from a refrigerator for for a temporary fix. But I did not know if the gas valve would affect the controlling system. I will leave changing things on my jeep to questionable practices . Safe Travels,. Vern Link to comment Share on other sites More sharing options...
rickeieio Posted February 24, 2018 Report Share Posted February 24, 2018 Maybe your seliniod has already passed enough air..... KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Wrknrvr Posted March 2, 2018 Author Report Share Posted March 2, 2018 Just for a update on the fan clutch seliniod. New part is in hand. Now to get it installed and the treadle valve subject satisfied. Then test all new parts. Yea now back to work,. Vern Link to comment Share on other sites More sharing options...
Wrknrvr Posted March 6, 2018 Author Report Share Posted March 6, 2018 I installed the new seliniod. Started the truck to leave the air build up so the fan would release from the clutch. When the air built up pressure the clutch released as it should. Then I checked for faults on the engine,. No faults. Safe travels,. Vern Link to comment Share on other sites More sharing options...
