Satellite and GPS Antenna Ideas?
VegasFlyer
We are looking for Mounting ideas for GPS and Sirius Radio antenna mounting.
For those who went with an exterior body mount, where did you locate it?
Has anyone used the mirror mounts?  Opinions on reception and ease of install?
Enquiring minds want to know...
John
Southern Nevada
2008 Volvo 780, D13, I-Shift
2017 Can-Am Maverick X3-RS
Sirius is on the passenger side mirror. No issues with reception so far. Install looked straight forward and simple...when the car stereo guy did it.
2014 smart Fortwo
For severla years, I used a simple steel bracket painted and secured with the mirror arm bolts. Used the magnet Sirius puck antenna.  Never had a problem but I didn't like the cable in the door hinge area.Sirius04.jpg
Later I screwed a steel plate to the right visor support post and moved the magnet Sirius puck antenna there.
Mark & Dale
www.dmbruss.com
They ran my wires inside the door along with the electric mirror wiring. No wire visible and nothing to bind in the door.
2014 smart Fortwo
6 hours ago, Scrap said:
Nowadays you use the sharkfin with all the stuff in it?
http://www.discountcarstereo.com/SFAS11x.html
You still need a place to mount it, unless you want to put a hole in the roof.
Mark & Dale
www.dmbruss.com
Problem is I don't know Volvos.  I was hoping you guys would know that part!  I can't imagine a 2010 still uses RAMI and there are very few truck antennas out there so I was guessing it already has the short mast or sharkfin.  It mounts just the same and you just change it out to the version with all the stuff in it.  With any luck the wires run up an A-pillar or up through a cabinet or something and lining doesn't have to come out.
Scrap,
Haven’t you heard, it’s all done with ball bearings these days.  You need to keep up with the memos from the corporate office....
Fletch
John
Southern Nevada
