Parrformance Posted February 8, 2018 Report Share Posted February 8, 2018 Patch it or reinforce it for now, definitely not any reason to worry about it, other than the DW turning an ankle 1100 miles from home. 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
jenandjon Posted February 12, 2018 Report Share Posted February 12, 2018 On 2/7/2018 at 3:19 PM, Moresmoke said: Stuff has started appearing on the front porch! As a side note, it is always an adventure when you get a new to you piece of equipment. On the way home, a couple times the engine didn't crank over quite like it should. Figured I'd pull the batteries, charge them individually, and load test them. All the battery connections were loose. Every single one. One battery shows 12.5 volts with a multi meter, but can't even trigger the relay in my load tester. Anyone else have a pothole in the middle of the cab floor of their Volvo? Must've been a real big boy that drove this thing. The whole center of the floor where the gearshift would be is bent down. Where did you get them? Did you build them yourself? Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Moresmoke Posted February 12, 2018 Author Report Share Posted February 12, 2018 24 minutes ago, jenandjon said: Where did you get them? Did you build them yourself? Discountramps.com These are 10000 lb rated, as I may want to load some things a bit heavier than a car. 7' 6" long should work just right with my bed plans. Link to comment Share on other sites More sharing options...
HERO Maker Posted February 12, 2018 Report Share Posted February 12, 2018 So what are those bed plans? With those ramps it had better be a very low bed, or maybe you're going to use an old plan of tilting the bed so that the break over is gone? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
jenandjon Posted February 12, 2018 Report Share Posted February 12, 2018 Thanks. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Ronbo Posted February 12, 2018 Report Share Posted February 12, 2018 Maybe a bet that tilts slightly to decrease the breakover angle. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
HERO Maker Posted February 12, 2018 Report Share Posted February 12, 2018 1 hour ago, Ronbo said: Maybe a bet that tilts slightly to decrease the breakover angle. It would have to Ron. But most of us are avoiding the cost of the hydraulics, or air bags, by getting the correct ramps for our higher beds. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Moresmoke Posted February 28, 2018 Author Report Share Posted February 28, 2018 Finally feel like I am making some progress. Slightly modified Jackalopee box. Out of the way spot to mount it. Got a gooseneck hitch installed. And hauled home the truck bed. Some assembly required! Link to comment Share on other sites More sharing options...
beemergary Posted February 28, 2018 Report Share Posted February 28, 2018 On 2/2/2018 at 9:52 PM, iddy said: Big5er I wanted to ask you in most states is it civilian in the scale house. I know every time I've gone into a scale house in California the only ones in there where CHP. I'm just wondering how other states do it. I belong to a couple old trucks groups. Don't even put Not For Hire--RV-etc. Nothing for them to ask questions about. This comes from DOT officers. Link to comment Share on other sites More sharing options...
beemergary Posted February 28, 2018 Report Share Posted February 28, 2018 On 2/2/2018 at 9:29 PM, Big5er said: Either you ARE commercial or you ARE NOT. Do not do something that you do not need to do"just in case". If you do not need it do not confuse them by doing it. It is not better to have it. It makes them wonder why. And, unless the sign at that scale said every vehicle over xxx weight needed to stop, you should never have gone into the scale. Stay out of the scales unless specifically told to enter. First, it is likely that they will not chase you down and if they do, your story of "I'm an RV and didn't think I needed to" will go better with a real trooper than possibly a civilian scale house worker. BTW: Nice truck. Like Carl I am partial to red Volvos also Belong to a couple old truck groups. Don't put Not For Hire---RV-etc. Nothing for them to ask questions about. This comes from DOT officers. Link to comment Share on other sites More sharing options...
GlennWest Posted February 28, 2018 Report Share Posted February 28, 2018 But my truck is an RV and is not for hire. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
noteven Posted February 28, 2018 Report Share Posted February 28, 2018 Isn’t a Not for Hire carrier like a Walmart truck - transporting their own company goods - not 3rd party goods? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Lance A Lott Posted March 9, 2018 Report Share Posted March 9, 2018 I have the same truck it's even red. I got it last April in Texas and drove it to Vermont. I got 9.7 mpg by the computer. I have removed the roof extention, the rear axle and the fifth wheel. I have put in a gooseneck hitch and pulled my trailer so I was happy for last summer. The only thing I didn't like about the I shift was it seems to go for too many gears at once, it's good on flat going or at speed but sometimes it drops too many rpms. It seemed better with the trailer on. As I got used to it I was able to put it into manual and take it up a few hundred rpms before putting it back in auto. It doesn't have the manual shift button. Yet. I was impressed with how it will pull and how sharp it turns. Link to comment Share on other sites More sharing options...
