Chuck Johnson Posted January 14, 2018 Report Share Posted January 14, 2018 We currently use a Splendide Combo 2100XC - washer/dryer (seven years now, with excellent results.) We have a 2018 DRV Santa Fe on order and have been looking at different washer/ dryers. Due to configuration of washer/dryer cabinet, it will have to be stackable type units. We are having a 220V outlet installed. Have looked at Whirlpool 7500 models (24" width) but it has very bad ratings. Splendide Ariston units - the dryer is 110V. Regular residential units or 27" in width and seem to be heavier. What models are you using? 110V vs 220V for dryer good / bad? Problems you have had with the units you are using? Any Santa Fe owners, what washer/dryer have you used. Thanks in advance. Link to comment Share on other sites More sharing options...
Chad Heiser Posted January 14, 2018 Report Share Posted January 14, 2018 Splendid makes a 240 volt dryer. We have one in our DRV. We are happy with our Splendide set. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
TXiceman Posted January 14, 2018 Report Share Posted January 14, 2018 With the 240 volt set up you cannot dry clothes if you are on a 30 amp site. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
GlennWest Posted January 14, 2018 Report Share Posted January 14, 2018 I'd put a gas unit in. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
TheLongWayHome Posted January 14, 2018 Report Share Posted January 14, 2018 1 hour ago, TXiceman said: With the 240 volt set up you cannot dry clothes if you are on a 30 amp site. Ken Genset Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 15, 2018 Report Share Posted January 15, 2018 19 minutes ago, TheLongWayHome said: Genset You cannot typically run a genset inside an RV park. Very few will allow it at all, and routine use would be even worse. Chad, have you measured the actual power use of your dryer? I know what service most require, but how much of that is actually being used? I don't have one to test. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
TheLongWayHome Posted January 15, 2018 Report Share Posted January 15, 2018 The current Energy Star top rated energy efficient dryers. 27" electrical LG DLHX4072 About $1,439, 1.965 kWh/load (avg.), 7.3 cu. ft. capacity 24" electrical Beko HPD24412W About $1,200, 0.625 kWh/load (avg), 4.1cu. ft. capacity. 27" Gas Samsung DVG54M87 $??, 2.420kWh/load, 7.4 cu. ft. capacity Link to comment Share on other sites More sharing options...
GetNThere Posted January 15, 2018 Report Share Posted January 15, 2018 I looked at the floorplan. Can the divider between the W/D and the pantry be removed and allow you to have a side by side w/d? If so, is it too late to make changes? Link to comment Share on other sites More sharing options...
Chad Heiser Posted January 15, 2018 Report Share Posted January 15, 2018 6 hours ago, Jack Mayer said: You cannot typically run a genset inside an RV park. Very few will allow it at all, and routine use would be even worse. Chad, have you measured the actual power use of your dryer? I know what service most require, but how much of that is actually being used? I don't have one to test. No Jack, I have not. Next time I run it, I will take some measurements. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Chuck Johnson Posted January 16, 2018 Author Report Share Posted January 16, 2018 21 hours ago, GetNThere said: I looked at the floorplan. Can the divider between the W/D and the pantry be removed and allow you to have a side by side w/d? If so, is it too late to make changes? Floor plan set - will have to use stackable. Link to comment Share on other sites More sharing options...
Chuck Johnson Posted January 16, 2018 Author Report Share Posted January 16, 2018 21 hours ago, GetNThere said: I looked at the floorplan. Can the divider between the W/D and the pantry be removed and allow you to have a side by side w/d? If so, is it too late to make changes? On 1/14/2018 at 3:52 PM, Chad Heiser said: Splendid makes a 240 volt dryer. We have one in our DRV. We are happy with our Splendide set. Heard from Splendide today, they no longer Manufacture a 220V dryer. Link to comment Share on other sites More sharing options...
FL-JOE Posted March 9, 2018 Report Share Posted March 9, 2018 We have had 2 different Spendide W/D stackable set ups in RVs, and now a Whirlpool W/D stackable set. To my knowledge in the past several years almost all RV dryers have been 110, not 220V. Probably the best way to help dry clothes faster in an RV dryer is to get the vented model. Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
