Furnace Noise
dan412
The furnace on our 2016 Montana 3820 FK fifth  wheel  makes rattle noise when the burner is on and furnace runs  a long time even when the thermostat is turned down. We are in Milton Florida where its 25 degrees outside. But the furnace will run for  hours without  turning off even if it's 70 degrees inside and the thermostat is turned down to 65.
2011 Volvo D13 485/1750  Eaton 13 Speed
2016 Montana 3820FK
16 minutes ago, WeBeFulltimers said:
Make sure the fan is set to "auto" on your thermostat.
X2^^. The rattle noise is likely in the sheet metal of the furnace housing or the plate at the tack of the furnace where the ducts are attached. On many fifth wheels, you can access the back of the furnace by removing the divider panel at the back of the basement.
Rob
2012 F350 CC LB DRW 6.7
2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows
Full-time since 8/2015
