Just Don Posted December 21, 2017 Report Share Posted December 21, 2017 I'm in the RGV in Weslaco TX. It's 80 and 73 percent humidity My two a.c. one is a couple month old are cooling some, but seems muggy inside and we have thermostat turned to 69 but thermostat says 75. Any suggestions! 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted December 21, 2017 Report Share Posted December 21, 2017 Are you able to pull the cover inside and look at the evap coil? Are either one of them iced up? If so, what does the ice look like? White frosty looking ice is an indication of lack of air flow, and hard clear ice is an indication of a drain problem. Did they work like they should before now? Link to comment Share on other sites More sharing options...
HERO Maker Posted December 21, 2017 Report Share Posted December 21, 2017 Don't leave the fan on auto. Switch it to high. Also check as Tom said. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Just Don Posted December 22, 2017 Author Report Share Posted December 22, 2017 Mine is inclosed units. Yes they was working fine b4 the last cold spell. I find a tech coming by tomorrow didn't figured I'd get one till after Christmas 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Just Don Posted December 22, 2017 Author Report Share Posted December 22, 2017 Got park electrician to come by both legs are showing 120. Hard to believe that every thing electrical is acting up. 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted December 22, 2017 Report Share Posted December 22, 2017 Now you can tell everyone the bad news.......... Link to comment Share on other sites More sharing options...
Just Don Posted December 22, 2017 Author Report Share Posted December 22, 2017 Lol Yup compressors went out in number 2. Has to replace #1 a month ago. Fun stuff Maynard 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Ronbo Posted December 23, 2017 Report Share Posted December 23, 2017 6 hours ago, Just Don said: Got park electrician to come by both legs are showing 120. Hard to believe that every thing electrical is acting up. That means nothing. With no load it will be fine. You need to place a load on the lines, like an ac, and check the voltage. It will probably be low. If you have one real high and one real low, it means an open neutral. Just outing a meter on the pedestal proves nothing. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
TXiceman Posted December 23, 2017 Report Share Posted December 23, 2017 Don. I got tired of fighting the parks low voltage and put a Hughes Auto Transformer in the trailer. It will boost the voltage 10% once it reached a preset lower voltage. With the Hughes showing that it was boosting, no low voltage in the trailer. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Pat & Pete Posted December 23, 2017 Report Share Posted December 23, 2017 1 hour ago, TXiceman said: Don. I got tired of fighting the parks low voltage and put a Hughes Auto Transformer in the trailer. It will boost the voltage 10% once it reached a preset lower voltage. With the Hughes showing that it was boosting, no low voltage in the trailer. Ken We do pretty much the same . Our coach is setup for 50 Amp . When we are on a 30 Amp site , I hook the Hughes in line every time . We still have to watch our 'consumption' , just a little bit , but , we get along fine . Goes around , comes around . Link to comment Share on other sites More sharing options...
Just Don Posted December 23, 2017 Author Report Share Posted December 23, 2017 Well I placed one A.C. 2 months ago due to motor burning up. Now the 2nd A.C. compressor went out on the other. Life's good. 2 hours ago, TXiceman said: Don. I got tired of fighting the parks low voltage and put a Hughes Auto Transformer in the trailer. It will boost the voltage 10% once it reached a preset lower voltage. With the Hughes showing that it was boosting, no low voltage in the trailer. Ken Ken I'll have to find out more about that from you. Thanks for the info P&P and Ken for the info 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Pat & Pete Posted December 23, 2017 Report Share Posted December 23, 2017 46 minutes ago, Just Don said: Well I placed one A.C. 2 months ago due to motor burning up. Now the 2nd A.C. compressor went out on the other. Life's good. Ken I'll have to find out more about that from you. Thanks for the info P&P and Ken for the info Don , here's a link to a Google search for Hughes Autoformer . https://www.google.com/search?source=hp&ei=sNY9WufLNYmOjwPP_YHwCQ&q=hughes+autoformer&oq=hughes+auto&gs_l=psy-ab.1.0.0i20i264k1j0l5j0i20i264k1j0l3.3876.9389.0.14422.13.7.0.0.0.0.4457.5679.0j1j4-1j1j9-1.4.0....0...1c.1.64.psy-ab..9.4.5678.0..0i3k1j0i131k1.0.Z3MvGe5YnFs Goes around , comes around . Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted December 23, 2017 Report Share Posted December 23, 2017 10 hours ago, Just Don said: Well I placed one A.C. 2 months ago due to motor burning up. Now the 2nd A.C. compressor went out on the other. Actually, that sounds about normal. Somewhere in the past you were more than likely running a low voltage condition. That caused the motors to run hotter than they should and shortened the life and it finally caught up with you. Link to comment Share on other sites More sharing options...
Just Don Posted December 23, 2017 Author Report Share Posted December 23, 2017 Every thing catches me now days I'm getting old and slow 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Just Don Posted December 23, 2017 Author Report Share Posted December 23, 2017 Can't wait till I get back to the PIC nice to have a winter home 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Just Don Posted December 23, 2017 Author Report Share Posted December 23, 2017 Can't wait till I get back to the POC nice to have a winter home finally that we love. 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted December 23, 2017 Report Share Posted December 23, 2017 POC? As in Port O'Connor? Link to comment Share on other sites More sharing options...
Just Don Posted December 23, 2017 Author Report Share Posted December 23, 2017 Yes it's what I heard some locals call it and b44 lol 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted December 23, 2017 Report Share Posted December 23, 2017 Looking forward to your return! Link to comment Share on other sites More sharing options...
