DKRITTER Posted December 21, 2017 Report Share Posted December 21, 2017 After pulling in this even we needed to dump the tanks, all was well until I tried to push in the cable for one of the grey tanks! The plastic sleeve/sheath that goes over the cable came loose from metal sleeve that mounts in the wet bay. Is there a way to take the black metal sleeve apart and reattach the plastic sheath? These cable valves have been nothing but a PIA since we bought this trailer. 2013 Newmar Dutchstar 4318 2019 F150 KR 4X4 BlueOx 10K Tow Bar Link to comment Share on other sites More sharing options...
Ronbo Posted December 21, 2017 Report Share Posted December 21, 2017 I abandoned my cable operated valves early because I could see that they would be a problem. I cut my pipes and installed valves outside the rv. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Kirk W Posted December 21, 2017 Report Share Posted December 21, 2017 10 hours ago, DKRITTER said: Is there a way to take the black metal sleeve apart and reattach the plastic sheath? You probably need new cables. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
lockmup68 Posted December 21, 2017 Report Share Posted December 21, 2017 make sure the cable run is straight as possible with long loopy turns and not sharp turns. I mounted my black tank cable outside of the water closet as, from the factory, there was a 90 degree turn to get over the frame rail out of the water closet. Get new cable and route it properly. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Ray,IN Posted December 22, 2017 Report Share Posted December 22, 2017 16 hours ago, Kirk Wood said: You probably need new cables. Yep, and put a drop of light oil on them 3-4 times annually. I have a choke cable on my smaller farm tractor (stored indoors) that will freeze in place if not lubed occasionally, and the run is practically straight, sloping down. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
DKRITTER Posted December 22, 2017 Author Report Share Posted December 22, 2017 Yeah, I was afraid I was out of luck. It looks like they are LaSalle Bristol valves and like I said they have been difficult to use since new no matter how much and how often they were lubed. They are braided cable style valves as opposed to solid wire style. BTW, thank god for the twist on valve we’ve always had on the trailer, we have a workable solution for the holiday at the kids house. Well I’m at a fork in the road since I’ll need to fix this one I’m going to replace all three. I’ll either go with a solid wire valve or maybe even electric. I have some trepidation about the electric. I have a 3” black and 2 1 1/2” grey tank valves. I don’t know what kind of real estate I have down below to work with so right now I don’t know what will fit. It wouldn’t surprise me if Forest River didn’t put in several loops bends and twists in the cables when they threw this trailer together. Do y’all have some recommendations for the replacements valves? Is there a very reliable valve? 2013 Newmar Dutchstar 4318 2019 F150 KR 4X4 BlueOx 10K Tow Bar Link to comment Share on other sites More sharing options...
