dennisvr Posted December 12, 2017 Report Share Posted December 12, 2017 What is the procedure for replacing the Orings and colletts in the push in fittings? I need to replace a couple that are leaking in the park brake valve. Thought I would ask before destroying a $250/$400 valve. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 12, 2017 Report Share Posted December 12, 2017 (edited) Take out the collet (metal piece) with your fingers or grabbing edge with needle nose pliers, use dental pics (from Harbor Freight) to “dig out” old o-ring. Sometimes they can be hard and brittle so be sure and get all the pieces. Center of connector will have small tube that will go inside airline for rigidity (it is solid in fitting and won’t come out with dental pics) so don’t be concerned. Clean connector with alcohol and q-tip or pipe cleaner and blow dry with air. Insert proper new o-ring ( sometimes requires manipulation with dental pics, not sharp point). Reinsert collet, cut off bit of airline past old indention from collet, be sure cut is square. Securely push back in connector and pull back slightly to get collet to catch. Not a hard job and the collets can be cleaned and re-used if not damaged. https://www.amazon.com/dp/B018A1X1VA/ref=asc_df_B018A1X1VA5298872/?tag=hyprod-20&creative=395009&creativeASIN=B018A1X1VA&linkCode=df0&hvadid=193227207088&hvpos=1o1&hvnetw=g&hvrand=17704666764576378080&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9013361&hvtargid=pla-373160725397 Edited December 12, 2017 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
HERO Maker Posted December 12, 2017 Report Share Posted December 12, 2017 Exactly with Carl said! He taught me! Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
dennisvr Posted December 12, 2017 Author Report Share Posted December 12, 2017 Thanks I've got the Orings so now I have to get the time to dig in and get these air leaks fixed. I should have asked if I had to replace the colletts at the same time. I thought I did and Volvo said I had to order a package of 10 at $2.95 ea. Lesson learned, ask questions from the experts on the forum first. Carl, I think I got the #s from one of your posts and Volvo said a few of the #s were mix up. I think it was the 3/8, they said the oring # was for the collett and vise a versa. I really applicate your post with the PNs, I don't think my Volvo dealer would have found them. Thanks again Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 12, 2017 Report Share Posted December 12, 2017 Dennis, Have to give credit to MrSeas for the parts numbers. He originally posted them. I posted the Harbor Freight picks I got. Don’t get the heavy duty ones. They don’t work as well as the flimsy ones. I actually took one of them and using needle nose pliers turned a tiny hook on the tip so it would grab the ring. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted December 12, 2017 Report Share Posted December 12, 2017 Dennis you don't need to replace the collets unless they are broken or a leg (??) is bent up badly (you can do that removing they). Just be sure that you have at least 1 spare for when you drop one because they are next to impossible to find. I had an extra thanks to Mr.Seas and I needed it. Now I carry spares. Changing is just like Carl said. I did find that on a hard O ring that it came out easier if you use a small screw driver and cut the O ring. Then fish out the pieces. Brad Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
HERO Maker Posted December 12, 2017 Report Share Posted December 12, 2017 Depending on which air system you are on, get rid of all air everywhere so the lines aren't pressurized. Pump your brakes if need be (as Carl and I found out). Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 12, 2017 Report Share Posted December 12, 2017 21 minutes ago, HERO Maker said: Depending on which air system you are on, get rid of all air everywhere so the lines aren't pressurized. Pump your brakes if need be (as Carl and I found out). Yep, air lines will not come out easily if the line is pressurized. Would also recommend buying a set of these. Makes life much easier and you will use them a lot. https://www.homedepot.com/p/Lisle-Air-Line-Disconnect-Set-5-Piece-LIS42400/207010907?cm_mmc=Shopping|THD|google|&mid=sBW7BiWnK|dt_mtid_8903tb925190_pcrid_195274179091_pkw__pmt__product_207010907_slid_&gclid=EAIaIQobChMIsbazreiE2AIVikoNCh06bwYzEAQYBSABEgKX5PD_BwE Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted December 12, 2017 Report Share Posted December 12, 2017 I use a 90 degree "pic" to stab and lift out the old o-ring, or pieces thereof. https://www.tylertool.com/gearwrench-84000-7-piece-hook-and-pick-set/kdtn84000,default,pd.html?ref=pla&zmam=31282435&zmas=47&zmac=723&zmap=kdtn84000&gclid=EAIaIQobChMIj6Dnre6E2AIVhoKzCh3DGQUdEAQYASABEgJ-fvD_BwE Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
dennisvr Posted December 13, 2017 Author Report Share Posted December 13, 2017 Looks like it will be awhile before I get to fixing the leaks. Just got done building a dump truck and now I've got about 75 ton of rock to haul and spread. That may keep me busy for a few days. Thanks for all the tips. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
GlennWest Posted December 13, 2017 Report Share Posted December 13, 2017 Does this work with the brass DOT fittings? I just been buying new ones. they are a little pricey. Understand a manifold though. need to practice on something. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted December 13, 2017 Report Share Posted December 13, 2017 9 hours ago, GlennWest said: Does this work with the brass DOT fittings? I just been buying new ones. they are a little pricey. Understand a manifold though. need to practice on something. Glenn, I have changed an o-ring on a brass fitting also. Same procedure. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 14, 2017 Report Share Posted December 14, 2017 I think it would be helpful if someone posted the list of part numbers in this thread....I cannot find them at the moment... Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
MrSeas Posted December 14, 2017 Report Share Posted December 14, 2017 (edited) 👍 Edited December 14, 2017 by MrSeas Quote Link to comment Share on other sites More sharing options...
dennisvr Posted December 14, 2017 Author Report Share Posted December 14, 2017 10 hours ago, Jack Mayer said: I think it would be helpful if someone posted the list of part numbers in this thread....I cannot find them at the moment... Here's the post I got them from. Volvo told me that a few were mixed up so you should verify what the part is when you order. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
dennisvr Posted December 14, 2017 Author Report Share Posted December 14, 2017 Here's another post from MrSeas with the PNs. MrSeas Major Contributor Validated Members 1,127 posts Report post Posted August 16, 2015 (edited) Go to the dealer and get the replacement parts for the push in connector. There is an "0-ring" and a brass collet that are replaceable. The O-ring is a greenish-blue color Here are the Volvo part numbers: 1/4 O-ring 85108484 price $0.48 (each) come in a bag of 10 1/4 brass collet 85108476 price $ 2.86 (each) 3/8 O-ring 85108485 price & 0.56 (each) come in a bag of 10 3/8 brass collet 85108477 price $ 3.10 ( each) 1/2 O ring 85108486 1/2 brass collet 85108475 To replace the parts is pretty straight forward. Please release all the air pressure in your system before attempting this repair! 1. Depress collar on fitting and remove line. 2. Remove brass collet. I use a pair of needle nose pliers. 3. Remove O-ring. Sometimes a bit of a challenge. I use a set of " dental picks" one straight and one with a 90" bend at the end. Use the picks to remove the O-ring. Most times it will be dry rotted and come about in prices. Make sure to remove all of the pieces. Insert new O-ring and be careful not to damage it. 4. Insert collet. Most times I will use the old one if it is still in usable shape. Most times the o-ring is the cause of the leak. 5. Trim off the end of the line before inserting into the "rebuilt" fitting. I like to do this when ever I have enough slack in the line. Sometimes it's not possible. When inserting the line into the fitting press the line in until it "bottoms" out in the fitting before you pull back on it to lock it in. 6. Pressure up your system and check for leaks. Sometimes a little wiggle on the line after it is pressurized will help it seat. After this less costly repair attempt you may still have to repair/replace your pass-thru. Good luck! On Edit: These instructions were written with the "Newbie" in mind.... Lots of folks have already been down this path. Not trying to get anyone upset. This is how I do this type of repair. No need to buy the "gold plated" Volvo brass fittings if I can just repair it. In most cases the "fitting" is fine it's just a worn out O-ring. Edited August 16, 2015 by MrSeas Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 14, 2017 Report Share Posted December 14, 2017 Thanks for the re-post Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted December 14, 2017 Report Share Posted December 14, 2017 List added to Resource Guide Quote Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
HERO Maker Posted December 14, 2017 Report Share Posted December 14, 2017 Thanks Mark! Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Mistybreaksthings Posted November 1, 2020 Report Share Posted November 1, 2020 On 12/14/2017 at 8:12 AM, dennisvr said: Here's another post from MrSeas with the PNs. MrSeas Major Contributor Validated Members 1,127 posts Report post Posted August 16, 2015 (edited) Go to the dealer and get the replacement parts for the push in connector. There is an "0-ring" and a brass collet that are replaceable. The O-ring is a greenish-blue color Here are the Volvo part numbers: 1/4 O-ring 85108484 price $0.48 (each) come in a bag of 10 1/4 brass collet 85108476 price $ 2.86 (each) 3/8 O-ring 85108485 price & 0.56 (each) come in a bag of 10 3/8 brass collet 85108477 price $ 3.10 ( each) 1/2 O ring 85108486 1/2 brass collet 85108475 To replace the parts is pretty straight forward. Please release all the air pressure in your system before attempting this repair! 1. Depress collar on fitting and remove line. 2. Remove brass collet. I use a pair of needle nose pliers. 3. Remove O-ring. Sometimes a bit of a challenge. I use a set of " dental picks" one straight and one with a 90" bend at the end. Use the picks to remove the O-ring. Most times it will be dry rotted and come about in prices. Make sure to remove all of the pieces. Insert new O-ring and be careful not to damage it. 4. Insert collet. Most times I will use the old one if it is still in usable shape. Most times the o-ring is the cause of the leak. 5. Trim off the end of the line before inserting into the "rebuilt" fitting. I like to do this when ever I have enough slack in the line. Sometimes it's not possible. When inserting the line into the fitting press the line in until it "bottoms" out in the fitting before you pull back on it to lock it in. 6. Pressure up your system and check for leaks. Sometimes a little wiggle on the line after it is pressurized will help it seat. After this less costly repair attempt you may still have to repair/replace your pass-thru. Good luck! On Edit: These instructions were written with the "Newbie" in mind.... Lots of folks have already been down this path. Not trying to get anyone upset. This is how I do this type of repair. No need to buy the "gold plated" Volvo brass fittings if I can just repair it. In most cases the "fitting" is fine it's just a worn out O-ring. Edited August 16, 2015 by MrSeas I need a part number for 1/8” collet and oring please. God bless you guys, this is going to save me alot of money and work. Quote Link to comment Share on other sites More sharing options...
Parrformance Posted November 1, 2020 Report Share Posted November 1, 2020 I have yet to run across to a 1/8 in Airline, what does it go to? Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 2, 2020 Report Share Posted November 2, 2020 2 hours ago, Parrformance said: I have yet to run across to a 1/8 in Airline, what does it go to? Pressure gauges on the dash. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Parrformance Posted November 2, 2020 Report Share Posted November 2, 2020 I wonder if it might be metric? 3mm o-ring. https://www.amazon.com/1-5x3mm-Metric-Buna-N-Durometer-Section/dp/B0180EQ0N8 Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
