charlyhors Posted December 11, 2017 Report Share Posted December 11, 2017 Hi all, We're presently in a small park, about 30 residents, and it has that rare thing - wifi of adequate range to reach our unit and kinda adequate capacity to stream Netflix. We generally get pretty good netflix streaming during the day (a bit watery on the colors), but that is when we're doing work and errands. In the evening, the reception is pretty on and off and frustrating - frequent stops for buffering, etc. Is there anything we can do on our end to help this - a signal booster, or whatever? Oddly, I have also noticed that the park network can be quite slow on surfing the web, but still can stream movies. Does Netflix have some sort of priority on bandwith that could cause that? Link to comment Share on other sites More sharing options...
TXiceman Posted December 12, 2017 Report Share Posted December 12, 2017 Park WiFi is not intended for streaming. WE have found several with a note to not stream and be considerate of others on the network. Streaming gobbles up bandwith. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
docj Posted December 12, 2017 Report Share Posted December 12, 2017 21 hours ago, charlyhors said: Oddly, I have also noticed that the park network can be quite slow on surfing the web, but still can stream movies. Does Netflix have some sort of priority on bandwith that could cause that? No, neither Netflix nor any other content provider has a priority under current Net Neutrality rules. All data must be treated the same. Of course, this is likely to change, but that's the case at the moment. Netflix utilizes software which enables it to accommodate significant changes in internet bandwidth and still provide an acceptable image. If you are on a marginal internet connection and you look closely at the screen during the show you will notice changes in the video resolution. This is how Netflix copes with varying internet speeds; it degrades your picture a bit to avoid having it pause while it rebuffers. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
