ms60ocb Posted December 9, 2017 Report Share Posted December 9, 2017 Has anyone found a current list of satellite channels on each of the three western arc Dish Satellite. Specifically would like Satellite 119 to get the most benefit from my Pathway X2. I found a list online and quickly identified the list several years and several changes old. Thanks Clay living primarily on the western ARC Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted December 9, 2017 Report Share Posted December 9, 2017 Quote https://www.satelliteguys.us/thelist/index.php?search=dn129&sub=true I thought one of the advantages of the X2 was satellite changing. Quote Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 9, 2017 Report Share Posted December 9, 2017 These lists are updated daily: http://uplink.jameslong.name Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Second Chance Posted December 9, 2017 Report Share Posted December 9, 2017 1 hour ago, Mark and Dale Bruss said: I thought one of the advantages of the X2 was satellite changing. It is - but some locals are either only - or only HD - on the Eastern or Western arc depending on where you are. The non-local channels can be accessed HD on either arc. Rob 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted December 9, 2017 Report Share Posted December 9, 2017 1 hour ago, Second Chance said: It is - but some locals are either only - or only HD - on the Eastern or Western arc depending on where you are. The non-local channels can be accessed HD on either arc. Rob But again, the X2 can do the EA and the WA. Why limit yourself to 119? Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 10, 2017 Report Share Posted December 10, 2017 3 hours ago, Mark and Dale Bruss said: https://www.satelliteguys.us/thelist/index.php?search=dn129&sub=true SatelliteGuys is no longer maintaining "The List" and the sub-lists. None of them can be relied on as accurate. The spot beam maps are likely still ok though... Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
ms60ocb Posted December 10, 2017 Author Report Share Posted December 10, 2017 1 hour ago, Mark and Dale Bruss said: But again, the X2 can do the EA and the WA. Why limit yourself to 119? The X2 is similar to the Tailgater, that is it can watch the three western channels, one satellite at a time. That is where the similarity ends. X2 Has a much larger dish, the X2 can watch the East or West ARC (but still one satellite at a time. BUTTTT X2 has two Outputs. allowing two receiver operation. The purpose of the satellite list is provide a gauge to what different channels we could watch at the same time on the same satellite. If I have 119, the rest be weeded out over time. Clay Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
