I was an early adopter of the Mobley device, and have it hard wired into my RV.  It has worked fine, I've used as much as 90GB in one month with no noticeable slowdowns.  But recently I am having undefined issues, and am wondering if anyone else has seen and fixed this?
When I log into my Mobley as usual, speeds are fine, everything works.  Then all of a sudden the Internet connection drops.  If I try to log back in I get the message "Cannot connect to the Internet".  If I then do a cold reboot it comes back up and works for a while, then the above cycle repeats.  It used to happen once a day, now maybe 5 or 6 times a day.  I know when it goes down not only for myself but by the looks I get from DW :(
I'm wondering if maybe it is location specific, as I am in an area where phone signals are weak.  Tomorrow, I move to a different location, and I'm hoping all will be well again (love the $20 unlimited!).   Meanwhile, if someone has any other ideas, I'll be open to anything...
== John
Share this post
Link to post
Our Mobley sometimes drops the connection after 24-36 hours, requiring a cold reboot, so I plugged the 120-volt power brick I use with it into small light timer set to turn it off for 30 minutes at 4 AM when we're unlikely to be using it. No problems after that. I've just switched the Mobley SIM back into my Netgear Unite hotspot though, so I can't say how long term that solution is.
Share this post
Link to post
Ours has worked nicely from day one , in locations from North central Illinois to Queen Creek , Arizona .
We unplug the unit every night and when we won't be using it for hours on end .
I noticed that the unit does produce a fair amount of heat when plugged in . We all know that heat is the 'enemy' of electronics .
Share this post
Link to post
I had more issues in my summer location than now. I have mine independant in my trailer on an off on power switch.  I still had non prime service a couple of time. I even thought it might have been affected  by weather. The signal to the mobley I mean.
Share this post
Link to post
We also turn off every night unless I’m doing some big download during the night, and also whenever we will be gone for several hours.
Share this post
Link to post
We have had the Mobley since March with no problems until we got to Northern Phoenix area. Works great most of the time but it seems the system goes down periodically. Unplugging doesn't help, just need to wait for the system to come back. Only have 1 green light when this happens.
We have been in other locations for a week or 2 and not had this problem so I am attributing it to problems in the area.
Just frustrating.
Share this post
Link to post
I've seen 18-24 hour forced reboot issues when the sim was in the Mobley. Since moving it to the Unite Explore I've run continuously without any reboot issues, and with no slowdowns at all, other than apparent tower congestion. Plus I have access to additional bands of service.
I would suggest that you put any device you have on a timer so that you eventually get a forced reboot from time-to-time. This works best on non-battery devices. On my battery devices I try to do manual reboots once in awhile. But on the Unite I have not done one for more than a month.
Share this post
Link to post
I don't know if it's just coincidence, and not that it might help in your situation, but on a previous cord with only the #4 and #16 pins wired we would see the reboot issue from time to time. Since I started jumpering the #4 and #5 pins it hasn't been an issue. Actually.. if I remember correctly... it was Pat & Pete that turned me on to that tidbit. I have 2 sons in two different states that use theirs for home internet. They run 24/7 without reboot.
I believe it's most definitely a mobley device vs. a service issue. Like Jack and others... I run my sim in a unite and have never looked back.
That being said... I'm strictly on battery power and only have mine on when in use. I agree with Pat and Jerry... "heat is the 'enemy' of electronics"... and it's a good practice to unplug daily. Sticking it on a timer sounds like a solid plan and the mechanical type can be had for what... $5 (?).
For connectivity issues.. I gotta say.. the Unite with even the $25 portable MIMO antenna is a "homerun" combo.
Share this post
Link to post
I do have times where it slows considerably and then a reboot gets me back at higher speeds. I leave mine on all the time. Once in a while I also find it has shut off and then I press reset. Having said that, I am pretty darn happy as I also have grand fathered verizon unlimited and I almost always prefer the Mobley.
Share this post
Link to post
I've had a continuing "no Internet access" problem during extended Mobley sessions with my Windows 10 laptop, logging the PC off of the Mobley and then logging back on brings back Internet access.  My Android tablet works flawlessly with the Mobley in the same locations.
I keep the Mobley powered up for days at a time with no change in it's performance.
Since the Mobley works fine with the tablet, but not with the Windows PC, I'm thinking it's a Windows to Mobley handshake issue, not temperature or anything else related to the Mobley.
Edited by Lou Schneider
Share this post
Link to post
Thanks for all the replies, but I think I found it and it was user error.  I always use a WFRanger to attach to the Mobley, than use the router of the WFRanger with all our (many) devices.  My WFRanger was sent to Idaho a few weeks ago for repair and I now have too many devices trying to log in to the Mobley.  So now I started policing who and what attaches to the Mobley and all seems well.
I get my WFRanger back this week and I should be back to normal.
== John
Share this post
Link to post
Once in a great while , we'll have the same type situation . That happens usually when the Mobley is left on with no one using it for hours on end .
Share this post
Link to post
We are still depending upon our Mobley as our sole form of internet access while recovering from Harvey.  Mobley solely no router.  How do you determine the 5 device limit?
Share this post
Link to post
Yeah. It does have a "sleep" mode when there is no active connection. I wonder if what's causing the disconnect issues is a failed "wake-up" call(?). Takes all of what... 30 seconds to reconnect? Hardly a deal breaker, right. ;)
If I remember correctly.. at one time I was reading about a dns refresh timer issue between the mobley and the actual tower signal that was user adjustable. There was some discussion on it, but I don't recall the specifics, aren't using my mobley so can't go look... and if I also remember correctly... it was in the mobley thread that disappeared into a black hole several months back.
Maybe the mention of it might jar someone with a better memory than mine on the specifics.
It's hardcoded into the mobley to only allow 5 IP assignments (devices).
Edited by Yarome
Share this post
Link to post
You might be thinking of the DHCP lease time discussion about extending it as a possible fix for connection drop outs. As I recall, there were mixed results reported.
Share this post
Link to post
THAT's the one! Much easier searching for information when you actually know what you're searching for. :lol:
Share this post
Link to post
Quote
Go to the Mobley ZTE control Panel for all kinds of info and settings.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Rvonthego.com
