woman_who_sees Posted November 29, 2017 Report Share Posted November 29, 2017 After 10 years of heavy use (we don't use our oven) , our microwave is finally dying. Can the one over the stove be replaced or do we buy a new one for the counter? Bill (DH), Jan (DW), Sunshine (DBird), and Gila and Tacobelle (DCats) 2004 Winnebago Sightseer "Folks are about as happy as they make up their minds to be" (after a cup of coffee) Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted November 29, 2017 Report Share Posted November 29, 2017 The microwave can be replaced. There is the standard household size 30" wide, very easy to get a replacement. If not 30" wide, then you have to shop more for a microwave that will fit the spot. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Solo18 Posted November 30, 2017 Report Share Posted November 30, 2017 You also have to consider how the current one vents, so you can buy a replacement that vents the same way because of the way they are set in cabinets. In other words, does air blow out the back, sides, top, or bottom? Link to comment Share on other sites More sharing options...
Dutch_12078 Posted November 30, 2017 Report Share Posted November 30, 2017 When our OEM Sharp microwave died, I found a 1000 watt Hamilton Beach unit at Walmart for $88 that fit the ventilated front trim from the Sharp with just some minor rebending of the mounting straps and adding a couple of small wood shims to support the feet. It's been in regular use for the past two years with no problems.The vents are in approximately the same locations as the Sharp vents. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
EagleEye Posted November 30, 2017 Report Share Posted November 30, 2017 Ours went out after about 8 years and we looked online for one from the same manufacture and found one that was very similar and it fit just like the old one. Didn't even have to replace the bracket on the wall. Dave and Marge 2010 Phaeton Motor Home Previous Mobile Suites 36 RSSB3 (for sale) and 2005 FL M2-106 Sport (for sale after 5er sells) Link to comment Share on other sites More sharing options...
Ray,IN Posted November 30, 2017 Report Share Posted November 30, 2017 2 hours ago, Solo18 said: You also have to consider how the current one vents, so you can buy a replacement that vents the same way because of the way they are set in cabinets. In other words, does air blow out the back, sides, top, or bottom? New units have a "box" that directs air flow, you remove it and turn to vent to the location you desire. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
masterdrago Posted December 5, 2017 Report Share Posted December 5, 2017 They can be tricky to install/replace. And yes most of the venting is pretty standard depending on who makes them. Not sure about the "off" brand in ours (High Pointe). I suggest taking it out and examining how things are arranged since so much of the RV industry does not use standard ware. 1st Time RVer 2018 Montana 3791RD, 2018 Ram 3500 DRW Link to comment Share on other sites More sharing options...
