Just Don
Gremlins and heat pumps
My rig is a 2012 brand doesn't really matter!
I'm in Tyler area and snow birding to South Texas 11/30.
I'M a f/t traveler..
Both of my heat pump Coleman won't come on and furnace is burning and smelling very bad bad.
Yes I turned it off...
But for now I'm wondering why both HP's aren't working there on separate breakers.
I bumped both up to 90. Never happened before. I did flip them off and on.
Was wondering if it could be the thermostat for the heat pump. I did replace my
front heap pump less than a month ago.
I do know heat pumps don't heat below a certain outside temp.
Mine are not blowing at all and temp is 50 outside yet there not blowing at all.
So I turned furnace on and it seems to not be burning properly.
So any suggestions of why heat pumps aren't working.
And what can I do with the furnace..
Thanks ya'll
Share this post
Link to post
Do both heat pumps work off the same thermostat? It seems strange that both would quit at the same time unless there is some common denominator between them like the power supply. Have you checked for power at each unit and at the t'stat?
Share this post
Link to post
No I haven't done that matter of factually I'M not good in that department, but I'll do a search on how to
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
