dennisvr
smart car ramps
10 hours ago, Jim & Wilma said:
These ramps are 19" wide and what I call "sissy ramps" . . .  that's what I bought.  The 12"wide ramps are also popular and some have reported they bend less than the 19" ramps.  I've not heard of problems with either.
Jim,
There was a forum member who’s ramps broke at the hinge, but he admitted to abusing them by dropping them off the bed several times.  Only ones I’ve ever heard of having issues.  Believe his were the 19” wide.  Saying that my wife used to sit in the car as it was winched off the truck (not on) in case my winch rope failed.  She could hit the brakes.  We don’t do that any longer in the event of ramp failure.  I have the Big Boy II (1000 lbs /ramp).  If I were going to drive the car on and off, would get the 12” 2000 lb per axle or if using the 19” would build some type of support at the hinge area in case it were to break.  Might be overkill and paranoia but a 4 ft fall in a smart isn’t going to end well for your back and neck.
Here is the broken ramp thread
Share this post
Link to post
Same ramps here as well.  I do find them heavy.  If I was doing it again I’d be using 12” wide ones to save some weight.  Discount Ramps and RVH Lifestyle both make 12” ones.
Nigel
Share this post
Link to post
I have 12" ramps.  Wish they had made 15's but at the time 4 or 5 yrs ago when embarking on this HDT trek, Bob at Discount ramps told me he had consulted with the HDT set and determined that 12's were adequate.  Obviously I didn't get that memo or I'd have suggested wider.
  • 12's take up less room and would be lighter than 19's.  I think 12's are 55 lbs each ramp.
  • I put a pce of 1/8 thick angle iron in the hinge to reduce the breakover angle so as not to rip off underbody parts.  Also put blocks under the dirt end so air dam doesn't hit the ground.
  • The Gen 1  have a different front and rear track, one is wider than the other.  New 17's and maybe 16's the track is the same front and back so when using 12" ramps you are not straddling the centerline of the ramps.  Pucker factor is reduced.
  • I winch mine up backwards and drive off forwards. Installed a trailer hitch on the rear of the car.   Pull seat fwd, sit on a pillow and watch front left wheel as driving off.
Share this post
Link to post
I'm leaning towards the 19" "sissy ramps".  Not sure if I will drive or winch it up.  One thing I have to check is where I will be storing them, that may dictate which ones I get.
Share this post
Link to post
Carl, thanks for the copying the hinge failure posting.  Interesting.
Some observations/speculation:
  1. The ramps with the failed hinge appear to be the 12" model.
  2. Per Discount, ramp weights:  12" = 56 lb and 19" = 54 lb (12" hook version is 59 lb)
  3. Wonder if the 12" and 19" use same hinge material specs, possibly giving 19" some advantage.
  4. And most important, Phil, you're still famous.
Share this post
Link to post
Regarding the hinge failure...  I have to wonder if perhaps something besides dropping the ramp couldn't have been a factor.  Having a "pucker moment" and jamming on the brakes while on the ramps would induce a huge load, right where you don't want it.
Just thinking....always dangerous.;)
Share this post
Link to post
  1. The ramps with the failed hinge appear to be the 12" model. Yup, thats what the pictures show.
  2. Per Discount, ramp weights:  12" = 56 lb and 19" = 54 lb (12" hook version is 59 lb)  The 19" ones are wider and lighter.
  3. Wonder if the 12" and 19" use same hinge material specs, possibly giving 19" some advantage. Same "materials" but totally different configuration if I recall.
  4. And most important, Phil, you're still famousAt least someone noticed :) Thanks Jim.
Edited by Big5er
typo
Share this post
Link to post
Could a guy take a couple light chains and ratchet boomers and set up a tension connection underneath the ramps?
Non- stretching connection. No straps.
Share this post
Link to post
May have to rethink getting ramps.  Glanced outside the window last night before sundown and noticed I don't have any place on the truck to store them "Dah".  Thinking of maybe getting the 12" ramps and sliding them under the car, but I think they are about 5 1/2" laying flat and not sure if I have that much room under the car.  Have to wait for sun up and go out and do some measuring.  Has anyone tried to slide them under the car?
Share this post
Link to post
I did for a while. Built a storage area now. My 2013 Smart(deer totaled it), the lower cover that covers the bottom of car broke and dropped down. Always believed the ramps did it. I just tooked some light weight 3/4" tube steel and welded up a storage area underneath back of truck.
Share this post
Link to post
Dennisvr
Cut four 2x10 about 10 inches square for the tires to sit on and that extra inch and a half should give you plenty of room under the car for the ramps.
Nigel
Share this post
Link to post
40 minutes ago, Nigel said:
Dennisvr
Nigel
Yes Nigel, I thought of that also if 1 1/2" would give me enough to clear.
Thanks
Share this post
Link to post
I considered this but decided against it. Wanted to keep bed flat. I do haul stuff on it occasionally. I try to save freight charges and have deliveries at freight depots. Drive to depot and pick up.
Share this post
Link to post
Howdy!
I have a set of Big Boy II ramps 12” wide I’m not using any more if anyone is interested in them.  I’m in Livingston at this time. Shipping is expensive  mine cost way over over $800.00 with shipping. I carried mine under our 2012 Smart Car that we carried on a Idaho Tote.
give me a call at # eight 3 two - 4 eight 3 - eight 5 zero 9.
“Happy Trails”
Chiefneon
Edited by chiefneon
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
