Purple Tractor Posted November 6, 2017 Report Share Posted November 6, 2017 What kind of wrench do I need to get the 5th wheel plate off this Volvo? The head end of the bolt looks round and the other looks like an axle nut cone. 2008 Volvo 670,D13, 13 speed,2018 Montana 3210MS Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted November 6, 2017 Report Share Posted November 6, 2017 Are you sure it is a bolt and not a plastic push in rivet that just pops out? Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
noteven Posted November 6, 2017 Report Share Posted November 6, 2017 Sounds like huck bolts. Resources Video "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
MrSeas Posted November 6, 2017 Report Share Posted November 6, 2017 opps! Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 6, 2017 Report Share Posted November 6, 2017 They are huck bolts and unless you want to buy the special tools to remove them (collar cutters), a torch or cutoff wheel is the easiest way to take them off. Just split the collar on each side and use a hand or air chisel to finish taking off the collar. The bolt will knock out after that. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
runaway parents Posted November 7, 2017 Report Share Posted November 7, 2017 Try heavy duty socket 3/4 inch breaker bar and a 6 foot piece of 11/4 inch pipe for a cheeter bar . it will break them loose or break them off. If that don't work split them with a cut wheel on a penut grinder. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 7, 2017 Report Share Posted November 7, 2017 31 minutes ago, runaway parents said: Try heavy duty socket 3/4 inch breaker bar and a 6 foot piece of 11/4 inch pipe for a cheeter bar . it will break them loose or break them off. If that don't work split them with a cut wheel on a penut grinder. What socket would you use? The head of the bolt is round and the nut side is a slick cone shape. The only way to get a huck bolt off is to break the collar by splitting it or cutting it. For a look at how they are installed, take a look at two animations. One is for a bulb type huck bolt and the other is for a cone style collar. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
runaway parents Posted November 7, 2017 Report Share Posted November 7, 2017 Have had truck for three years. been that long ago since I removed the commercial fifth wheel don't recal exact size of socket. But I do remember I cracked a couple of sockets before I went to a heavy duty socket. Took about 2 hours to remove hitch.I don't own a torch .Just a socket, breaker bar, 6ft pipe, and a cut wheel. Link to comment Share on other sites More sharing options...
Scrap Posted November 7, 2017 Report Share Posted November 7, 2017 Use a 22 and a 30 deep socket for the 13 & 16 sizes if I remember right. But that is for the old Huck-Fit. Those noisy friggen things finally left my life in 2006. The Bobtails (the rivet head ones) you gotta slice as close as you can on the collar (nut) flange. Don't use a plasma. If there is water between the collar and the bolt will f-up your torch bad. Cost me a bunch of $. Huck-Fit collar: Link to comment Share on other sites More sharing options...
Ronbo Posted November 7, 2017 Report Share Posted November 7, 2017 Smoke wrench is the easiest. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted November 7, 2017 Report Share Posted November 7, 2017 16 hours ago, Brad & Jacolyn said: Are you sure it is a bolt and not a plastic push in rivet that just pops out? Sorry I misunderstood .I saw plate and thought linsence plate. I need a beer. Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
rickeieio Posted November 8, 2017 Report Share Posted November 8, 2017 11 hours ago, Brad & Jacolyn said: Sorry I misunderstood .I saw plate and thought linsence plate. I need a beer. Yes you do. It might improve your spelling. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted November 8, 2017 Report Share Posted November 8, 2017 13 hours ago, rickeieio said: Yes you do. It might improve your spelling. I tried 3 different spellings and could not even get close enough for the spell checker to fix it. Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
RandyA Posted November 8, 2017 Report Share Posted November 8, 2017 We call them a "Blue tipped wrench". AKA - Oxygen/Acetylene with cutting tip. Just watch that hot slag doesn't land on an air line. Don't ask me how I know that . Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
