"Reason for edit" caused other issues
Bill Joyce
I replied on the thread "What type of RV do you Full time in?" under forum "Sharing the Fulltime Lifestyle" and then realized I had a misspelling and went to edit it to fix it.  I could not save the change and noticed a "Reason for edit" showed up, so I put in my reason and it still would not save.  After a few times I gave up.  I went back to add a new comment and up popped my original message which i fixed and saved.  Now I have two message and I can't reply on that topic without adding a new variant, since it starts with my original message.  Really weird.
4 minutes ago, Barbaraok said:
I've noticed that we are getting multiple posts from people, is it because the system is running so slow?
Yes the software is slow . But , it's also because folks aren't  paying attention to what's going on and get impatient . Push the button time after time and end up with multiple posts . Then wonder why .
Often , I get a 'saving' where the Submit Reply button is . Then seconds later it switches back and the post goes public .
Goes around , comes around .
I agree. I won't say this is the case all the time but I too have noticed that sometimes when posting it says "saving" it is like watching paint dry. Other times it is immediate.
Obviously the problem I had has not happened to any of you, since your replies make no sense in my case.  I never got "Saving"", it just sat there after I hit "Save" and I was patient.  No one else has mentioned getting a "Reason for edit" field that they needed to fill out, so I suspect that showing up was the cause of my grief.  I suspect it is a forum software feature that is supposed to be disabled, but somehow popped up due to there being a poll, or a quote in the reply, or some combination of where the moon and sun were in the sky. I have been at this a long time people, I am not a newbie.
I have had the 'reason for edit' , but that was a while ago and haven't seen it since . Yer prolly right that it has to do with the spirits in the sky . LOL
In fact , I get the 'reason for edit' every time I edit a post . I just don't see it as it's just below the bottom of my screen . I've never put any reason in that space and never had a problem , otherwise .
I  usually edit my post but don't fill out the "reason for edit" and the edit post usually go through. I wonder if you had a weak internet  signal and the system stalled at the edit section of the post. Was this just a one time Blurp?
Edit went OK just now, and I will ignore the "reason for edit".
Interesting, after the edit was accepted, the Escapee program shut down and restarts itself, with the edit intact.
Greg
8 minutes ago, gjhunter01 said:
I have never filled out the "reason for edit" and my edit post usually go through. I wonder if you had a weak internet  signal and the system stalled at the edit section of the post. Was this just a one time Blurp?
Interesting, after the edit was accepted, the Escapee program shuts down and restarts itself.
Greg
I don't think I've ever experienced that^ .
On edit : let's see what happens .
On edit 2 : nothing . just went right to public display with no restarts or any other interruption .
It seems to restart on the first edit, second or third edits go right through. I have noticed this on other post edits, but didn't think anything about it.
Edited again. Yes, it did shut down "Internet Explorer" after a 30 sec delay. It could be my security settings.
Second edit went through with no shut down, same as before.
Third edit went through with restart. Upper left box read - "Reason For Edit" caused other issues- Bugs and Features Request - Escapee Discussion Forum (not responding) Then went through restart and third edit was there. (Updated with forth edit)
Greg
Submitting a post or editing. Click summit and nothing happens. Wonder if it didn't take. Click summit again. Nothing. Close out disgusted. Go back, 2 posts.  This is with solid connection too.
That seems to be the nature of this software. Next time hit submit once then wait a few seconds and then hit F5. Scroll down and you will probably see your post.
