lockmup68 Posted October 29, 2017 Report Share Posted October 29, 2017 For those that use a macerator pump hard mounted, how does the washer drain work? On my Teton, the washer does not drain into the gray tank, but direct to the discharge tube. How would the macerator pump work in this situation? thanks, Shannon 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Devilishjim Posted October 29, 2017 Report Share Posted October 29, 2017 The water will freeflow through the macerator pump as long as nothing floats in to obstruct the discharge and if the discharge hose is lower than your rv. If you have a grey water tank open then the water can back into that tank Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
Jack Mayer Posted October 29, 2017 Report Share Posted October 29, 2017 I have a bypass built around my macerator. So I leave the grey open, black closed and the bypass open. This is normal operation, and the water flows around. To macerate the black I simply close the bypass and the grey and open the macerator shutoff.... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
lockmup68 Posted October 30, 2017 Author Report Share Posted October 30, 2017 12 hours ago, Jack Mayer said: I have a bypass built around my macerator. So I leave the grey open, black closed and the bypass open. This is normal operation, and the water flows around. To macerate the black I simply close the bypass and the grey and open the macerator shutoff.... Thanks Jack. This was the idea in my head, but glad to know it’s been done. Thinking hard of going this route. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
