MilesAndSmiles Posted October 26, 2017 Report Share Posted October 26, 2017 The propane detector in our 2004 motorhome recently started giving false alarms, so we decided to replace it. The original unit is a CCI Controls Pre Tell 26, Model No. 7773.0. I bought a Safe T Alert 30 series "Classic Propane Alarm" on Amazon that says it replaces most CCI Controls flush mount propane Alarms without modifications. But... The CCI alarm has three wires (two red and one black), going into a three-prong connector. This plugs into another 3-prong connector in the RV, which also has two red and one black wires. The replacement has one read wire and one black wire, with no connector. So, 1) Are these compatible or do I need to return the new unit? 2) If they are compatible, how do I wire it? Do I connect all 3 reds together with a wire nut, and the two blacks with another? Thanks in advance. Jeff 2004 Fleetwood Southwind 37A Retired and loving it! www.milesandsmiles.us Link to comment Share on other sites More sharing options...
Just Don Posted October 26, 2017 Report Share Posted October 26, 2017 as far as hooking it up is all I did when replacing mine, They should be changed every 5 years actually. I did a LP gas and a carbon monoxide combo unit 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
oldjohnt Posted October 26, 2017 Report Share Posted October 26, 2017 I just noticed the Yellow (replace unit) light came on in my LP Gas detector, I'm shopping Flea Bay, Amazon and Camping World myself, there's only two 12 VDC wires ran to mine, so I will be following this thread for recommendations. John T Link to comment Share on other sites More sharing options...
oldjohnt Posted October 26, 2017 Report Share Posted October 26, 2017 1 hour ago, Just Don said: I did a LP gas and a carbon monoxide combo unit I will likely go with a new replacement LP Gas ONLY detector in place of the one I already have. I prefer my Carbon Monoxide Detectors up closer to ceiling height and my LP Gas down on floor level. Actually, I'm going to use TWO Carbon Monoxide Detectors (front and rear) since I sometimes in daylight ONLY hours use an LP Gas Big Buddy Mr Heater which has a low oxygen sensor plus I keep a window near it cracked, saves gas versus my forced air furnace. John T Link to comment Share on other sites More sharing options...
Barbaraok Posted October 26, 2017 Report Share Posted October 26, 2017 Sounds like you have an alarm that shuts off propane? Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
lenp Posted October 27, 2017 Report Share Posted October 27, 2017 As noted above, your old one had a propane shut off feature. See https://www.safehomeproducts.com/shp2/data/manuals/7773.pdf for the wiring diagram for the old one. If it were me, I would replace with a similar unit. Shutting off the flow of propane in the event of a leak is a good thing! Edit: Additional studying of the above link shows the third wire IS NOT a solenoid control lead. One red lead is for connection to the battery positive and the other goes to the convertor positive lead. Therefore, you can tie both red leads to the battery positive if you want but I suspect only one needs to be connected. The one you bought should work fine - just connect the new unit positive lead to the wire coming from the battery. Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
