johnschnee Posted October 24, 2017 Report Share Posted October 24, 2017 In recent months my Dear Wife has been noticing a faint "musty" smell emanating from our 14 Bounder's A/C ductwork when the A/C cycles on: it seems to last for just a minute or so, then it disappears. We use our rig about 1/2 the year & it doesn't seem to matter if it's been in storage for 2 months or if we are the middle of a months-long trip & running the A/C on auto for days. Suggestions? Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 24, 2017 Report Share Posted October 24, 2017 Have you cleaned the intake filter ? That can get pretty dirty , even in an otherwise clean rig . Goes around , comes around . Link to comment Share on other sites More sharing options...
Kirk W Posted October 24, 2017 Report Share Posted October 24, 2017 Dusted air can develop that problem over time whether in use or not. It may be just some accumulation of dust and dirt, could be bug nests and webs, or it may be some type of mould. We had that in our Cruise Master after several years of constant use and resolved it by using aerosol deodorant (Lysol) sprayed generously into the air intake with the air conditioners operating. If that type of effort does not resolve the issue it is possible to have those ducts cleaned by a duct cleaning professional, I have been told. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
johnschnee Posted October 24, 2017 Author Report Share Posted October 24, 2017 We clean the intake filters regularly but thanks for that suggestion. We will try the Lysol. Thanks!! John Link to comment Share on other sites More sharing options...
dartmouth01 Posted October 26, 2017 Report Share Posted October 26, 2017 If you want to check inside your ducts, look for "USB endoscopes" on Amazon. They can be fairly cheap, plug into your phone or computer for live feed viewing, and taped to some bendy wire, you can snake it around some corners. Good luck! Link to comment Share on other sites More sharing options...
Ray,IN Posted October 26, 2017 Report Share Posted October 26, 2017 On 10/24/2017 at 8:53 AM, Kirk Wood said: Dusted air can develop that problem over time whether in use or not. It may be just some accumulation of dust and dirt, could be bug nests and webs, or it may be some type of mould. We had that in our Cruise Master after several years of constant use and resolved it by using aerosol deodorant (Lysol) sprayed generously into the air intake with the air conditioners operating. If that type of effort does not resolve the issue it is possible to have those ducts cleaned by a duct cleaning professional, I have been told. That is the ultimate advice! Since I have asthma, I bought Filtrete sheet filter material and taped it to the outside of the ceiling unit intake. We were amazed at how quickly it got dirty, and had to change it once a week when the unit was running constantly. Now in the MH I use Filtrete replaceable household filters for our basement unit. They last about a month. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
fly2low Posted October 26, 2017 Report Share Posted October 26, 2017 I have used this product in an auto, and it works https://www.thoughtco.com/product-review-auto-air-duct-cleaner-281648 only challenge for an RV is it needs to be applied through the AC intake while the unit running similar to Kirk's idea, different product Rich and Carol 2007 Dynamax DQ 340 XL Link to comment Share on other sites More sharing options...
jerryneal Posted October 28, 2017 Report Share Posted October 28, 2017 Take a dryer sheets and place in front of the filter. Sometime the ducts get a stale smell from lack of use. Change every 2 or 3 days for about a week. Jerry and Joan 2014 Ford F350 with 6.7 turbo, TrailerSaver 2014 40' Heartland Gateway Fifth wheel iLoveRVlife.com Link to comment Share on other sites More sharing options...
