Kimmipi Posted October 23, 2017 Report Share Posted October 23, 2017 We have a McKenzie Dune Chaser. We are replacing all the old flooring with new and want to install a new toilet at the same time as we're getting ready to go full-time. We're considering the Dometic 320. It weighs 37lbs. The current Thetford weighs 10lbs. Will the new Dometic weigh too much? Thank you for any information. Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 23, 2017 Report Share Posted October 23, 2017 Weight is a relative thing . Important for sure . WHY are you considering a 320 ? Does your current toilet not function properly ? Or are you just wanting to spend money ? Or ??? I see . You double posted only changing the title . Buy the 320 and don't worry about the 27 pounds . Goes around , comes around . Link to comment Share on other sites More sharing options...
Devilishjim Posted October 24, 2017 Report Share Posted October 24, 2017 Just now, Pat & Pete said: Weight is a relative thing . Important for sure . WHY are you considering a 320 ? Does your current toilet not function properly ? Or are you just wanting to spend money ? Or ??? I see . You double posted only changing the title . Buy the 320 and don't worry about the 27 pounds . I would imajine cuz one is plastic and the other one porcelain Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 24, 2017 Report Share Posted October 24, 2017 42 minutes ago, Devilishjim said: I would imajine cuz one is plastic and the other one porcelain Matters not . They'll buy the 320 . Goes around , comes around . Link to comment Share on other sites More sharing options...
57becky Posted October 30, 2017 Report Share Posted October 30, 2017 Just make sure the 320 will fit the space, as it's the elongated version and takes up a bit more space. If it doesn't fit, the 310 may be a better fit. Link to comment Share on other sites More sharing options...
