GlennWest Posted October 13, 2017 Report Share Posted October 13, 2017 My next big project will be a small building on my property. It will be a very modest dwelling. Metal insulated building with plumbing. I will finish somewhat. Great fishing there. My daughter and grandchildren will use it more than us. Lol. Considering solar only and maybe batteries if needed. It will have a septic system but an arobic type. Need power for pumps. Required there, no traditional sewer system. Any susgestions 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Daveh Posted October 13, 2017 Report Share Posted October 13, 2017 Glenn you will need batteries but here I don't know if I would go with Lithium due to cost. I think battery weight and size reduction justifies the cost with rv usage but for a stationary location I would just get some big lead acids. Of course if you think the batteries may end up in your fifth wheel then lithium makes sense. In that case I recommend you buy cells and make your own pack. Plenty of expertise here to help you along. If you havent already look over Jack Maye'rs RV discussion http://www.jackdanmayer.com/rv_electrical_and_solar.htm. I would also look at Solar Bob's materials as he uses solar in a similar application. I think the link is in Jack's materials. You should start with your pumps (lights? refrdige? tv?) anticipated amp draw and then plan backwards from there. In new construction you have a blank canvas so you can do it right. Also be sure not to cheat yourself by undersizing wires. Another common error. Dave and Lana Hasper Link to comment Share on other sites More sharing options...
GlennWest Posted October 13, 2017 Author Report Share Posted October 13, 2017 All lighting will be led, tv? maybe. Very temp dwelling. We will be in Teton. Will have a pad and want to share solar power with it. Just thoughts for now. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
