Recently I saw the question posted on facebook, "Can I install a household shower head in an RV" The answer of course is yes. they both use standard pipe fittings as well as the faucets in the kitchen and bathroom. I decided to get a shower head that is not labeled for RV use and see what happens. I was completely underwhelmed, it was just like I had put the factory shower head back on. So now I'm back in the comfort of my oxygenics. Check it out if you have some time!
https://www.youtube.com/watch?v=jXr6jFOMVVk
Jed Arnold
2015 flagstaff V-lite 28WRBS
2x Battle Born Lithium batteries
2000 watt Ames inverter/charger
King Quest DirecTV sattelite
2011 Ram 1500 Quad Cab Big Horn 4x4 for tow vehicle
  • Replies 65
  • Created
  • Last Reply
All the plumbing fixtures in our MH are gold-tone Moen household fixtures, they work great; even though they are 17 yrs old..
Welcome to the Escapee forums! Happy to have you with us.
We put an Oxygenics Body Spa shower head in ours and we love it. I find that particular shower head is rapidly becoming the most popular replacement items in the RV community. I know of only one RV manufacturer who installs them at the factory, probably because the cost more than the cheapies found in most of our rigs.
Actually, when I compared total flow per minute, my Moen shower head has a lower flow rate than oxygenics. Assuming line pressure and internal pipe diameter remains the same, the only way to increase perceived output pressure at the shower head is to use smaller openings or less openings in the shower head, or whatever you use at the outlet.
Before comparing total flow output,I once thought about trying an oxygenics head, but the company does not make them with a brass finish or gold-tone.
My shower head doesn't match my bath faucets, and neither match my sink faucets...water pressure was more important to me and I'd rather match everything else to the thing that gives me a good shower.
2007 Keystone Springdale 245 FWRLL-S (modified)
2000 F-250 7.3L SRW
Cody and Kye, border collie extraordinaires
Latest departure date: 10/1/2017
Find us at www.nomadicpawprints.wordpress.com
I just took the "low flow" regulator out of our current shower head and it greatly improved our shower experience!  I don't think there is much difference in water used when I can rinse soap quickly versus having to take all day to get rinsed  because of poor pressure.
Happy Trails,
Jim & Ginger/Nomad Hikers
Retirement 12/2016
Full-time 04/2017
VanLeigh Vilano/Ford F350
Blog site - https://www.trailer2trail.com/
Facebook page - https://www.facebook.com/search/top/?q=trailer2trail
The Oxygenics uses air to increase the pressure of the water so it is using the same amount of water as the lower pressure heads but with more output pressure...you get the best of both worlds...save water and have great pressure
2000 F-250 7.3L SRW
If conserving water is the goal, a oxygenics shower head is not going to work well. I often travel in the desert areas where getting water is an issue.   Currently I am in a remote forest service campground that usually has water but it has been turned off for the season. My wife and I want to shower and wash hair with less than 1 gallon of water each. To do so we use a trickle of water not a high pressure spray.
My Oxygenics has a adjustable flow knob at the base of the shower head, where the hose connects.  Really cuts down on the amount of water coming out, but doesn't reduce the pressure.
Al & Sharon
2006 Winnebago Journey 36G
2020 Chevy Colorado Toad
San Antonio, TX
X2.
And another option. http://www.rvnetwork.com/topic/120606-ecocamel-jetstorm-vs-oxygenics/
I still use my Oxygenetics on the outdoor shower, but I do prefer the jetstorm for my every day indoor.
That defies logic and the rules of hydraulics, unless you have a pressurized air source to mix with water flow.
Don't know how they do it with their venturi... ain't a mathapaticiology gradiate or even know how they get root beer in those wax a penny candy, but they work. Live it, love it. It must be magic. :P (at $39.95)
Quote
Edited 7 hours ago by Ray,IN
While I agree about the rules of Hydraulics.  However the Oxygenics shower head gives a satisfying, fairly hard spray, even at water flows down to about 1 gallon/minute.
Al & Sharon
San Antonio, TX
Perception defines individual reality regardless of universal dogma.
BTW: Oxygenics in RV and at home.
Jan and Rocky Larson, Volunteers, USFWS , 9,300 hours each. 29 refuges since 2006. 2 new each year.
2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty, Blue Ox Aladdin, 300 watts solar, 5 Optima group 31 AGM's, 2000w PSW inverter
Philippians 4:11-13 KJV
3 hours ago, Al F said:
....  However the Oxygenics shower head gives a satisfying, fairly hard spray, even at water flows down to about 1 gallon/minute.
This is the issue I have.  I want to use a gallon or less for my entire shower. With the oxygenics shower head I could use most of that amount just adjusting the water temperature.
That would dictate about a 30 second shower . I think I can afford to splurge a bit more than that . :wacko:
Goes around , comes around .
I usually take 5 minutes or so for a Navy type shower.   Using a lot of water can mean cutting short a trip and heading to an area that has water.  This has nothing to do with the cost of water.  If you always camp with hook ups, then there is no issue or reason to conserve.
