toilet issue
hasti14
If your foot pedal has a covering, take it off and see if you can see where the spring is - spray some silicone spray in and around that.  Ours was the same, sprayed some in and away she went.  I now do it about every 3-4 months.
Barb
Barb & Dave O'Keeffe
SPK# 90761 FMCA #F337834
The spring could also be weak or about to break.  It's pretty simple to replace and not expensive.  You just need to make sure you have the correct part number.  For Dometic/Sealand toilets there are at least two different styles and they aren't interchangeable.
Sandie & Joel
WiFiRanger Ambassador
The ball valve or bowl seal could be dragging and cause the same issue. OP doesn't state the make and model of toilet. If you put a little silicone grease on the ball valve and work the valve a few times and it closes OK, replace the bowl seal. Then do two things. Never use harsh cleaners in the bowl (Dollar Tree foam cleaner works good). I use a Thetford toilet seal conditioner once a month per bottle directions. I replaced my first seal at 4 months old and never had to replace a seal ever since and we are 13 FTing.
'12 Excel Limitied 33ft GKE Full Timing '14 Chev 3500 CC DRW D/A named Bullet
  • 3 weeks later...
it is a thetford toilet with the side pedal. other forum suggested using plumbers silicone grease. did that and it seemed to improve for a bit. will have to go on thetford site and check out the schematics to see if a spring is involved. thanks
There is a screen where the water enters the assembly below the spring.  Found ours full of 'crystals', used swab dipped in vinegar to clean out - that helped some.  Also pour vinegar every month of so into the toilet bowl to help dissolve any calcium/magnesium carbonate precipitate which keeps the ball rolling smoothly.
But the silicon spray was really the thing that cured our foot pedal problem.
Yea the Thetford Aqua Magic with the side arm---been there done that---Ordered a repair kit worked for a while but not long. My next repair was MUCH more effective. I threw it in the trash and bought the Dometic 310.
Dave and Lana Hasper
We have the Thetford and have been dealing with a the lifting foot solution for a couple of years now. Then a month ago it started not holding water either. So I got the model# from the rear bottom of the toilet, Aqua Magic Style II Model# 42054 and ordered a kit from Amazon# 34120 waste ball & seal, for around $13. I remove the two nuts near the floor flange along with the water line and took the toilet outside. Turning the toilet upside down you will see two screws inside from the back, once removed this will allow the toilet to be split in half. Then it's just a matter of removing the rubber ball seal and replacing it. Note: clean the ball surface with steel wool or SOS pad so it doesn't scratch/scour the new seal. The kit also includes a new seal for the floor. Now our toilet snaps closed when you release the lever. Hope this helps.
Greg
