jerryneal Posted October 1, 2017 Report Share Posted October 1, 2017 Need to boost my Mobley reception. The Weboost Drive 4Gs and similar models aren't in the budget this year. Has anyone had success using the Weboost 4G-S cradle and a Mobley? Plans are to use a painters pole and a cellular truckers antenna and bungie to the RV ladder. Jerry and Joan 2014 Ford F350 with 6.7 turbo, TrailerSaver 2014 40' Heartland Gateway Fifth wheel iLoveRVlife.com Link to comment Share on other sites More sharing options...
Smitty77_7 Posted October 1, 2017 Report Share Posted October 1, 2017 I have one. And for the price it's a worthwhile addition. Due to other changes, I'm now carrying the 4G-S in our toad, in case it is needed while traveling. They run very hot. So place them on an appropriate surface (I use a piece of floor tile.). And keep a spacer between the Mobley and the cradle. I use a small piece of plastic about 3/8th thick, and rubber band either the Phone, Mobley, MiFI, whatever the device is, into the cradle. And make sure you have an adequate ground plane for the antenna. In a pinch, I've attached it to the metal fans up over the dash, and found they were enough to help pull in the signal... But up on roof is best, either a 10" saw blade, or Home Depot has 8" X 10" galvanized metal in the roof section. I have two of those together up on the roof, calked down, and they make a good ground plane. Now, just to be clear, thought he 4G-S will help in many situations, it is not a big dawg cell amp... So their will be times when you it just won't get the job done for you. But again, for the price to performance - I believe it is a good tool to have in the Communication Arsenal:)! $.02:)! Best of luck to you, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Devilishjim Posted October 2, 2017 Report Share Posted October 2, 2017 Your plan is what I am doing with a Wilson Sleek works fantastic, gets me a signal in the trees where I couldnt before. Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
