SWharton
Router and Mobley
Can I hook up my router I brought from home to my Mobley? I am finding 5 connections a limitation. Anything special about doing this?
Share this post
Link to post
Nothing special.  I have mine to a WiFiRanger router from it to a switch that feeds DTV Genie, Smart TV, Blue Ray player, Laptop and Desktop via hard wired.  And wireless to 2 iPads & a iPhone pus a Amazon Echo & Dot
And the Mobley thinks it is only hooked to 1.
Edited by Biker56
Share this post
Link to post
Most "home" routers only support getting your internet through Ethernet (wired), via a cable or DSL modem.  To hook up the Mobley your router will need to support USB tethering, along with support for the Mobley, or "Wifi as WAN", where it can take an incoming wifi signal and rebroadcast it with a new SSID/passcode (wifi name/password).   Travel routers like a Hootoo Tripmate (around $40 from Amazon) or a more full featured router like Pepwave and WifiRanger makes, can do the job.  I use a Pepwave Surf SOHO.
Share this post
Link to post
There is a thread on Howard Forums covering this topic:
http://howardforums.com/showthread.php/1894920-ZTE-Mobley-USB-Tethering-ASUS-Router-and-probably-others!/page1
I purchased an GL-MT-300N for $20 from Amazon:
https://www.amazon.com/GL-iNet-GL-MT300N-Pre-installed-Performance-Compatible/dp/B01AL7P1FU/ref=sr_1_9?ie=UTF8&qid=1506692446&sr=8-9&keywords=travel+router
It plugs into the USB port on the side of the Mobley.  It provides better signal and overcomes the 5 device limit using the stock firmware.  I tried some other firmware listed in the thread, but found them less stable and went back to the factory version.
Safe Travels...
Share this post
Link to post
OK. I looked at thee routers everyone has mentioned and decided I really don't understand most of this. Howard forum was way beyond my interest and knowledge. Looking at all of this it seems the simplest is  GL-MT-300N that K4Rz has used. This is what I want is to be able to connect all my devices, whether using them or not, to the router. I have a total of 8 devices(I think). Most are not active on a regular basis(like the printer and Tivo Roamio). Unless someone can tell me that the GL-MT-300N  will not work I will order one.
Comments? and thanks.
Share this post
Link to post
PM on new forum is not working for me either.  Email seems best.  k4rs at yahoo dot com.
Safe Travels...
Share this post
Link to post
I see a discussion on Howard Forums that indicates ATT has pulled the unlimited data plan.  Thinking appears to be that those that have the plan are OK for now.  Reading a couple of different threads, it seems like the Mobley might not be available for purchase.  A couple of days ago, it was available on the ATT website.  The discussion also said folks that have removed the SIM and put it in other devices was what prompted this action.  FYI     I my case I know nothing about most things.
Edited by usnlt
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Rvonthego.com
