jpcoll01 Posted September 27, 2017 Report Share Posted September 27, 2017 I have a 31' Gulfstream B Touring and I want to mount an LCD to the outside (under awning) while we are parked (mainly for tailgating). My intent is to store the TV underneath or on the bed while in motion so I want something that will allow me to remove the entire TV and mount. Anyone done this? Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted September 27, 2017 Report Share Posted September 27, 2017 A lot depends on how big of a TV you want to use, but you could use a bracket similar to THIS ONE. Do you know that there is sufficient backing to hang a TV on the side? Link to comment Share on other sites More sharing options...
Kirk W Posted September 27, 2017 Report Share Posted September 27, 2017 1 hour ago, jpcoll01 said: Anyone done this? I have not, but I do like a challenge. My first thought was to use a storage bay but from the pictures of a BT that I found it doesn't seem at all practical. I would put the connections for power and antenna into a bay, even if it means a fairly long cord/cable. I'm thinking that the bracket suggested might serve well but it is important to locate some framing for it to attach to and be very careful of electric wires that may be embedded in the wall. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
jpcoll01 Posted September 27, 2017 Author Report Share Posted September 27, 2017 Thanks for the feedback. I have hung several in my home with the mount below. It provides great articulation possibilities, which I think will be important in an outdoor setting. My main concern was the leverage/weight when the TV is extended. I haven't dug into the walls of the BTouring, so should I assume wood studs? I'd also like it to be fairly clean, so I was thinking insert two fairly large bolts into stud and then flair the bottom of the holes in the mount so I can simply slide them over the bolts and then slide down to secure and gravity will hold it while setting still, clearly would remove completely (besides the bolts which would be sealed with some kind of sealant) but they would only need to stick out less than 1/2" in my estimation. Link to comment Share on other sites More sharing options...
Big Greg Posted September 27, 2017 Report Share Posted September 27, 2017 I would not assume wood studs. Here's a link to their construction. Check out item #8. Greg http://www.gulfstreamcoach.com/motorhomeconstruction Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
Pat & Pete Posted September 28, 2017 Report Share Posted September 28, 2017 9 hours ago, jpcoll01 said: I have a 31' Gulfstream B Touring and I want to mount an LCD to the outside (under awning) while we are parked (mainly for tailgating). My intent is to store the TV underneath or on the bed while in motion so I want something that will allow me to remove the entire TV and mount. Anyone done this? Maybe you should consider mounting your TV on an adjustable pedestal , rather than compromising the side of your RV . Goes around , comes around . Link to comment Share on other sites More sharing options...
Kirk W Posted September 28, 2017 Report Share Posted September 28, 2017 16 hours ago, jpcoll01 said: I haven't dug into the walls of the BTouring, so should I assume wood studs? It would be very unusual today to find wood studs in any motorhome exterior walls. If you look at the link provided by Big Greg, it clearly indicates that the framework is of box aluminum. Quote 7. High-gloss gelcoat exterior fiberglass 8. Vacuum-bonded laminated walls with welded square-tube aluminum frame and high-heat-resistant urethane adhesives 9. Azdel synthetic substrate that is odorless and Formaldehyde-free; won't rot, mildew, or absorb water; insulates better yet weighs half as much as plywood 10. High R-value rigid EPS wall insulation 11. Vinyl-clad interior wall panelling 2 I think that your plan is very risky, but we really don't know enough to say if it could work. It could be possible if you can locate the aluminum frame, but they do not state the size of that box aluminum or its thickness. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oldjohnt Posted September 28, 2017 Report Share Posted September 28, 2017 In the event you could somehow locate the precise location of aluminum frame members (I doubt it) horizontal or vertical, and drill/attach to them I might trust hanging a TV. Perhaps a regular household type hanger described above. If that's not practical, at the very least when I have hung "items" on an RV exterior I have drilled all thru the wall and use large flat "fender" type washers (and decorative finish) inside and out to sort of compress and sandwich the hangers. I'm NOT talkin much weight here guys. NOTE just because I have done this with certain light weight items and never had a problem, I'm NOT suggesting you try it based on anything I said or did lol I don't want the blame for pulling the wall off your RV John T Link to comment Share on other sites More sharing options...
Pat & Pete Posted September 28, 2017 Report Share Posted September 28, 2017 I think the pedestal is the best option . Simple TV mount . Easy slip on and off . It would be easily stored . Easily positioned to eliminate glare , no matter which direction you happen to park . And , you won't have to worry about , whatever holes you drilled through your RV , leaking . Then , there is the thought that maybe the next possible buyer of your rig could shy away when they see 'alterations' . Goes around , comes around . Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted September 28, 2017 Report Share Posted September 28, 2017 Flat screen TVs are not very heavy, so I would think that if you found a stud or cross member you could put a mount on there that is close to the wall. There is one like that on the side of my fiver so I can take the 40 inch TV in the living room and hang it outside. I wouldn't put a mount with an arm on there, but would put an ultra slim mount on. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 28, 2017 Report Share Posted September 28, 2017 Easy enough to find the studs in an RV wall, just need to get up before the dew burns off. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
jpcoll01 Posted September 29, 2017 Author Report Share Posted September 29, 2017 On 9/27/2017 at 9:12 PM, Pat & Pete said: Maybe you should consider mounting your TV on an adjustable pedestal , rather than compromising the side of your RV . Thanks everyone, a pedestal does seem less risky. Will put some thought into it this weekend. Link to comment Share on other sites More sharing options...
lhowemt Posted October 26, 2017 Report Share Posted October 26, 2017 Regarding funding the studs and the above comment to identify to locate them in the morning before the Dew Burns off -has anyone tried using a flir infrared camera to locate studs? Link to comment Share on other sites More sharing options...
