Inverter Ports
SWharton
We have 4 ports on our inverter(Magnum MS2000). Red, Green, Blue, Yellow.
Yellow-temp sensor(understand)
Blue-goes to remote in MH(I believe)
Green-????
Yellow-????
It is hard to see the plugs, need to use a mirror and the power switch blocks most of it. Does anyone have any idea about the plug usage and what is plugged in?
__________________
Operators manual downloadable ....
http://www.magnum-dimensions.com/product-inverter/2000w-12vdc-pure-sine-inverter-charger-ms-series
"Network Connection Port (green label) – a RJ11 port that accepts optional network capable accessories (i.e., Auto Gen Start or Battery Monitor)".
"Stack/Accessories Connection Port (red label) – a RJ11 port that allows series stacking, and accepts the optional RSAs (Remote Switch Adapters) for remote on/off switch operation. Info":
Green-????
Yellow-????
__________________
Maybe this manual will help :
http://www.magnum-dimensions.com/sites/default/files/MagArchive/64-0007-12-04-MS-Manual.pdf
Goes around , comes around .
