Bobi and Dick McKee Posted September 9, 2017 Report Share Posted September 9, 2017 The driver tires on our Sportchassis are down to 6/32 with 21000 miles on them. I expected about 40000 miles on a set. The tires are Goodyear G670 22.5. The wear is even across all 4 drivers. At that wear rate I will need to replace them before our next long trip. Is that that rate of wear "normal"? Thanks in advance. Dick Link to comment Share on other sites More sharing options...
SWharton Posted September 9, 2017 Report Share Posted September 9, 2017 Have you ever had a front end alignment. We had that problem with our toad and had never done a front end alignment. Once we had new tires and had the alignment all has been fine. Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted September 9, 2017 Author Report Share Posted September 9, 2017 The fronts are fine. Its the drivers that are wearing. Link to comment Share on other sites More sharing options...
ms60ocb Posted September 10, 2017 Report Share Posted September 10, 2017 I have almost 30,000 miles but not worn that much. I had a wheel alignment at 22,000. The rear axle alignment was adjusted a bit. One difference I noted the RV pulled differently. Before the alignment .I never was able to use the truck mirrors to shot gun sight down the RV side to road to rear. I was always seeing lots of road on drivers side and no road on passenger side . After the alignment I see miles of road on either side if no wind. Clay 2015 FL Sports Chassis Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
