billnbos Posted September 2, 2017 Report Share Posted September 2, 2017 I have a 93 King of the Road 5th wheel that hasn't been moved in years. I cant get the large slide to retract and have no idea where the slide motor is located. Any old 5th wheel owners out there that can help. Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 2, 2017 Report Share Posted September 2, 2017 Is there any sound at all when you try to operate the slide. How old are the batteries. Ais there any water in the batteries. Can you plug the RV in. If so do the lights come on and brute as they should. That's enough to get started on what is wrong. May need more info,. Vern Link to comment Share on other sites More sharing options...
Kirk W Posted September 2, 2017 Report Share Posted September 2, 2017 12 hours ago, billnbos said: I cant get the large slide to retract and have no idea where the slide motor is located. Does this mean that there is another slide which does retract? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Big Greg Posted September 2, 2017 Report Share Posted September 2, 2017 Verify your batteries are good!! Is there a battery disconnect switch that might be off? Greg Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
billnbos Posted September 2, 2017 Author Report Share Posted September 2, 2017 The small slide does work It is plugged in to shore power. Tried to had crank it in and the end of the crank shaft broke. trying to locate the motor so maybe we can change it out, Link to comment Share on other sites More sharing options...
Big Greg Posted September 2, 2017 Report Share Posted September 2, 2017 Are both slides electric or hydraulic? Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
jc2 Posted September 2, 2017 Report Share Posted September 2, 2017 Just for grins and giggles, look under the pull out steps of your 5ver and see if there is a small black box of sorts mounted somewhere in that area. If so, see if is has a lid/cover that will come off. About 20 years ago, we had a 1993 StarCraft 5th wheel and the big slide quit working as I started to bring it in. There was a small black box of the type/location that I described and inside was a stubby round glass 50a fuse for that slide. Replaced with another and the slide worked after that. Got an extra fuse if needed for the future and of course never happened again while we owned it. 2010 Newmar Dutch Aire 4304-Spartan Chassis-Cummins ISL 425hp-2013 Chevrolet Equinox AWD Towed-SKP# 120487-FMCA #402879- Link to comment Share on other sites More sharing options...
billnbos Posted September 3, 2017 Author Report Share Posted September 3, 2017 Electric Link to comment Share on other sites More sharing options...
Big Greg Posted September 3, 2017 Report Share Posted September 3, 2017 If the other electric slide works then the battery(s) and disconnect switch should be OK. That leaves a possibility of 2 fuses/breakers and the one for the bad slide is bad, the slide switch is bad, or the motor is bad. It's vey possible there could be a corroded power connection or loose connection. I'd use a meter and check for 12v at the switch first as a start. You said the hand crank broke, when you first tried to bring the slide in with the switch did it make any noise? If it did it's possible it's jammed and popped a fuse or breaker, if it made no noise then it's back to a fuse/breaker, switch, motor, or connection problem. Start checking for 12v in the circuit from the battery to the slide motor. Greg Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
